Author Topic: Th350 to manual swap question  (Read 15635 times)
Offline BidEquation78
« on: September 06, 2014, 09:55:12 pm »
Hi, today I went to a local salvage yard and priced out parts for a manual swap in my 82' C10. The donor truck I found was I believe an 87' C3500 6.2 diesel with a 4 speed(granny gear). I was quoted $75 for everything (flywheel, bell housing,clutch, pedal assembly and all) if I pull it. Anybody have experience on a swap, and if so how much modifying is required? Thanks
82' C10
93' Festiva 5 speed
Offline Engineer
Re: Th350 to manual swap question
« Reply #1 on: September 07, 2014, 09:11:44 am »
The '87 used a hydraulic clutch. Your '82 used mechanical linkage. The firewall will be slightly different and mounting the clutch master cylinder might be kind of difficult.
What engine is in your '82? I don't remember the 6.2L diesel coming with a 4-speed so the flywheel may be a mystery. In any event the 6.2L used a couple of different flywheels on the automatic tranny and neither will work with a gas engine.
If that '87 has mechanical clutch linkage then that is a sure sign that the transmission was swapped in. If the donor truck has mechanical linkage then great, it will adapt to your '82 better.
If the truck has a 4-speed column I would get that too so you don't have the issue of the auto shifter on the column, and 4-speed shifter in the floor....... Unless you like the bubba effect.
I knew a guy back in the day who swapped in a 4-speed. With his old auto column he drove out the pin that held the auto shifter in the column. About half the time when he went to start the truck he would have to put the auto column back into "park" so the starter would work. With the auto shifter missing the column shifter would rotate out of position while he drove.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline winky
« Reply #2 on: September 07, 2014, 09:15:28 am »
i swapped my 77. with it being an 87 donor it should have a hydraulic clutch.
You will want to get the bracket that holds the clutch sensor(same as a brake pedal sensor) I cant remember if they are on the same bracket as the brake pedal sensor..
measure the difference in the transmissions i be leave the manual is shorter (may require drive shaft modifications)
as far as install goes..
Cut a Hole in the fire wall for the master cylinder (some trucks already have the hole or a stamped circle)
change out your pedals (just un bolt and bolt in new ones)
measure transmission and see if the cross member is going to rest in the same place (may require drilling new holes in frame)
un do the neutral safety switch on bottom of column and wire it up to the clutch sensor
install master cylinder (make sure to us the 2 rods that come off the pedal "cage" they reinforce the firewall, if you dont use them the fire wall will flex when using clutch and possible crack/break leaving you with a clutch you cant disengage.
Blead your master cylinder and see how you like your new trans
sorry, i have a very busy day so i kinda just jotted this in here, if you need any help or pictures of my setup just pm me or ask here for some and ill do my best to help
EDIT:
Engineer beat me too it lol
« Last Edit: September 07, 2014, 09:17:18 am by winky »
« Reply #3 on: September 07, 2014, 12:14:35 pm »
Thank you both for the detailed replies! I really appreciate it :D! In response to Engineer, my truck truck is a 350, the donor truck looked to be all original and I was very suprised to see a 6.2 4 speed especially in a 2wd setup... Seems very rare to me! Currently on lunch break so ill post a pic up this evening
82' C10
93' Festiva 5 speed
« Reply #4 on: September 07, 2014, 04:49:27 pm »
Here is the donor I found. It is in fact a 6.2! Such a shame to see it rusting into the ground but all drive-train parts seem extremely solid! Also the price is more than fair.( if you look close enough someone tried removing the 1 ton sway-bar and got about halfway there lol)
82' C10
93' Festiva 5 speed
Offline roundhouse
« Reply #5 on: September 22, 2014, 07:21:23 am »
Funky lookin box for the heater A/C
Grab that sway bar too
Some hot rodder  will want it
« Reply #6 on: September 22, 2014, 09:15:42 am »
I'm planning on going back to the yard(which is 2 hours away) within the next few weeks to get the assembly, so ill take some pics of all the trucks they have!
82' C10
93' Festiva 5 speed
Offline mechanic58
« Reply #7 on: September 24, 2014, 10:00:52 am »
That 6.2L Diesel will also have a Buick/Olds/Pontiac bellhousing bolt pattern on it. Won't bolt up to a Chevrolet engine. (The bottom bolt on either side will and the dowel pins will line up, but the other 4 bolt holes will not line up)
I like junk
Offline Dan75k20
« Reply #8 on: September 25, 2014, 07:09:57 pm »
6.2S had a bop bell housing
Offline csdineley
« Reply #9 on: September 25, 2014, 09:58:28 pm »
You will also need the transmission floor hump. Auto trucks have a low hump and manual and 4x4 trucks had a higher hump.
1987 V20 Custom Deluxe, Vortec Headed 350, SM465,Np205 14Bff 4.10
Offline Dan75k20
« Reply #10 on: September 27, 2014, 12:12:49 pm »
87s didnt have removable trans humps
Offline roundhouse
« Reply #11 on: September 29, 2014, 07:13:47 am »
I've seen on other sites where people put a NV3500 from a late model Chevy behind the 6.2
How'd they do that if it has the BOP pattern ?
« Reply #12 on: October 04, 2014, 03:07:30 pm »
would my best bet be buying a new bell housing? around my area most manual trucks either are automatic, or they have the entire drive train yanked.
82' C10
93' Festiva 5 speed
Offline roundhouse
« Reply #13 on: October 05, 2014, 10:17:39 am »
Search on Colorado K5.com
I'm not certain the 6.2 has a BOP pattern
Several swap threads on there
« Reply #14 on: October 05, 2014, 04:17:54 pm »
I will be sure to check that out roundhouse, thanks  :D... Also, what transmission would you guys suggest?(used from a salvage yard of course). preferably 5 or 6 speed but I also don't want to break the bank.
82' C10
93' Festiva 5 speed
