Author Topic: Cooler lines  (Read 4235 times)
Offline Chisholmcody
Cooler lines
« on: September 10, 2014, 02:25:10 pm »
The transmission cooler line has a hole in it and is dripping out at a steady rate and I was wondering if any one has a link on were I can find these lines
Re: Cooler lines
« Reply #1 on: September 10, 2014, 10:39:27 pm »
     We need year, make, model of truck and what transmission & line would be helpful.
     Places like auto parts warehouse, summit, rock auto has them, but I could not check to see it they listed them since I did not know anything about your truck.
Offline 78BIG-TEN
Re: Cooler lines
« Reply #2 on: September 11, 2014, 09:59:42 am »
You could always cut where it is leaking,and flare and install a union.You could even use a compression fitting but they tend to vibrate loose and leak
Re: Cooler lines
« Reply #3 on: September 11, 2014, 03:49:22 pm »
1978 chevy Cheyenne with l6 250 th350 transmission recently rebuilt
Re: Cooler lines
« Reply #4 on: October 09, 2014, 11:11:04 pm »
inlinetube.com or classictube.com
Re: Cooler lines
« Reply #5 on: October 10, 2014, 12:13:15 am »
Sorry forgot to update my status on this but I ended up just running new lines along the frame and then used some electrical brackets from home depot to hold it down securely. And so far it has held up well!
