Author Topic: 1990 tbi fuel inlet?  (Read 3571 times)
« on: September 13, 2014, 03:09:16 am »
so the truck im going to get monday has been sitting for 10+ years i want to bypass the tank and hook a fuel tank right up to the tbi via the inlet. but what size is the fitting on the inlet? i could just cut the fuel line and spice it in but i might use this motor later and dont want to ruin it now just to replace it later
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: 1990 tbi fuel inlet?
« Reply #1 on: September 16, 2014, 11:07:01 am »
3/8 fuel line will slip right over the metal line. For the purpose of "jerry rigging it" you could disconnect the fuel line on the outlet side of the filter, slide the flare nut out of the way, force the 3/8 rubber over the flared metal line have a separate electric pump to your 5 gallon gas can and by pass the regular tank that way ,just make sure the main pump in the truck tank is disabled. That's how I've done it in the past.
« Reply #2 on: October 09, 2014, 10:45:48 pm »
Disconnect the 16mm inlet and 14mm outlet and run a pump with some EFI rated hose on a barb to it...
