Author Topic: Standard Brakes - 84 Chevrolet C10  (Read 16450 times)
Offline CanadianC10
« on: September 13, 2014, 03:16:01 pm »
currently running hydroboost in order to clear valve covers of my Cadillac motor.
having to remove the booster in order to lash valves is a pain, along with the extra hoses.
anyone running standard brakes on these trucks? where did you get the master cylinder?
Thanks.
Brennan Curtis
1984 C10 LWB
CADDY 507
TH400
Frame twister
12.59 @ 108 .. 1.94 sixty
Re: Standard Brakes - 84 Chevrolet C10
« Reply #1 on: September 13, 2014, 04:39:08 pm »
My 86 C10 came with manual brakes, I am sure you can get the correct master from any auto parts store
Offline roundhouse
« Reply #2 on: September 13, 2014, 10:19:06 pm »
Can't you use flex hoses at the MC?
Then you just have 2 bolts
I've seen off road only squarebody trucks with lots of frame flex use the braided steel flex hoses from the MC to the frame
The frame and body twist so much that the stock hard lines break off where they thread into the MC
Also google at the power brake setup on a early (66-77) Bronco
THey have a bellcrank pivot that relocates the booster at a 45 degree angle to clear the valve cover
Might work on your truck with a little fab
What kind of engine you running  ?
A 500?
Or a north star ?
« Last Edit: September 13, 2014, 10:21:24 pm by roundhouse »
Offline CanadianC10
« Reply #3 on: September 14, 2014, 02:08:05 pm »
Roundhouse, I don't understand what you mean by flex hoses at the master cylinder, im trying to ditch the power booster and use a standard master cylinder.
Its a 507 Cadillac and no matter how much I angle the booster it will not come close to enough room, these engines are wide and I am running 3 1/2" valve covers to clear the shaft rockers.
Zieg85, does your master cylinder just use the two top studs as opposed to the 6 used when a power booster is used?
1984 C10 LWB
CADDY 507
TH400
Frame twister
« Reply #4 on: September 14, 2014, 04:25:20 pm »
2 bolts are used
Offline CanadianC10
« Reply #5 on: September 14, 2014, 06:44:13 pm »
Roundhouse, I now understand what you were getting too, I figured there was similar bracket for the master cylinder that the booster used.
with that being said I wonder If I could use the master cylinder off the booster.. I'm assuming the manual master cylinder has a bigger bore or something along those lines.
1984 C10 LWB
CADDY 507
TH400
Frame twister
Offline roundhouse
« Reply #6 on: September 14, 2014, 08:52:22 pm »
The manual MC is slightly different but not much
Did you take a look at the early bronco bracket?
Offline CanadianC10
« Reply #7 on: September 15, 2014, 03:31:58 pm »
that is a good idea for swaps ill keep that in mind.
as for me I doubt my cam would pull enough vacuum to bother with.
1984 C10 LWB
CADDY 507
TH400
Frame twister
« Reply #8 on: September 15, 2014, 03:40:59 pm »
FWIW, manual brakes are not that much harder to stop than power assist.  I like the manual feel better and 1 less thing to go wrong.  It is so much easier change a steering column with manual as well...
Offline CanadianC10
« Reply #9 on: September 15, 2014, 06:22:08 pm »
I will be going to manual steering also.. this truck is getting more performance then street ability. although I will not drive it any less on the street.
1984 C10 LWB
CADDY 507
TH400
Frame twister
« Reply #10 on: September 15, 2014, 07:13:17 pm »
Just like my 86, originally RPO N51  Power steering delete
Offline CanadianC10
« Reply #11 on: September 15, 2014, 08:48:58 pm »
wouldn't happen to have a manual steer box to sell would you?
1984 C10 LWB
CADDY 507
TH400
Frame twister
Offline roundhouse
« Reply #12 on: September 15, 2014, 08:52:41 pm »
Do The manual brakes in the 73-87 have a different pedal ratio ?
« Reply #13 on: September 15, 2014, 09:03:41 pm »
I don't believe so
« Reply #14 on: September 15, 2014, 09:05:11 pm »
Sold my last extra about a year ago.  They are really hard to find but I know of one, I will see if the guy wants to sell it.
