Author Topic: where to mount a spare?  (Read 8557 times)
Offline 84k10355ci
« on: September 15, 2014, 08:55:24 pm »
Kind of a strange question but where are you guys mounting your spares? I'm running 37s with a 4" suspension and 3" body lift and my spare is the same, so size is kind of an issue. I have a short bed 84k10 so I also want to avoid mounting it in the bed since I could use as much bed room as possible since it is a short bed. I do alot of wheeling so I need to be cautious of mounting it low because I don't want to snag the tire on something or get hung up on it. Any ideas? Thanks guys
Re: where to mount a spare?
« Reply #1 on: September 15, 2014, 09:02:29 pm »
How about safari style and go with a roof rack.  I've seen some tasteful ones.
Offline 84k10355ci
« Reply #2 on: September 15, 2014, 09:16:58 pm »
I was honestly considering that but I haven't found any pictures of any to give me an idea on how it would look
« Reply #4 on: September 15, 2014, 09:26:19 pm »
If it were me I would harvest one from a Suburban in a salvage yard and cut it down to fit.  Then make one to attach to it.
Offline 84k10355ci
« Reply #5 on: September 15, 2014, 09:28:06 pm »
Hmm doesn't look like many people have made one for the k series, could be a pretty cool project. Thanks for the ideas :)
« Reply #6 on: September 15, 2014, 10:04:13 pm »
I like the lowest left hand one on the white truck.
« Reply #7 on: September 16, 2014, 08:50:23 am »
      You could always incorporate it into the back bumper with a swing out tire carrier.  We did it all the time on the jeeps we used to off road with.
Offline MajMike
  • Retired USAF Major, Disabled Vet
« Reply #8 on: November 23, 2014, 05:22:01 pm »
Check out tiregate.com.
http://www.tiregate.com/
'82 K5 4wd Silverado w/ 6.2 diesel w/ Banks Turbo and rear disk conversion, J-code intake w/ EGR delete, more to come . . .
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #9 on: December 19, 2014, 07:41:33 pm »
That tire weighs a lot keep that In mind whatever you decide ,it will also see a ton of vibration.what's your current rear bumper situation? You maybe farther ahead trying to stand it upright in the box behind the cab and mounting it tight that Way. Even then your going to still get a fair amount of deflection.
Offline roundhouse
« Reply #10 on: December 20, 2014, 10:19:57 am »
With a 3" body lift you might be able to put a skinny 37 on top of the engine like the old Suburus used to do
