Author Topic: One speaker not working  (Read 8824 times)
Offline dc7432
« on: September 16, 2014, 04:59:52 pm »
I just installed the following all new wiring and components
Pioneer MVH-X370BT
Front Pioneer TS-A878 3.5 60W 4 ohm
Back 4x10 160 W
10" kicker sub 600W
600W kicker sub
First two days worked well then all speakers stop when I disconnected the front left speaker wires (pioneer 3.5) the other three came on sound great reconnect front left all stop. Any ideas? Short in speaker? Thanks in advance
Re: One speaker not working
« Reply #1 on: September 16, 2014, 06:06:02 pm »
Swap the front speakers side-to-side to see if the problem follows.
Offline dc7432
« Reply #2 on: September 16, 2014, 08:11:24 pm »
I swap speakers and it works however I get the same thing runs on three but the fourth shuts down the sound when I disconnect the fourth sound comes back sub stays on throughout.
« Reply #3 on: September 16, 2014, 08:17:00 pm »
So, if any three speakers (excluding the sub) are connected the three work; but, if you hook up the fourth, none work?  Recheck all your wiring and connections.
« Reply #4 on: September 17, 2014, 07:18:36 am »
     The fourth speaker you are hooking up is either got a problem with the wiring or the speaker itself.  If you switched sides with the problem speaker, and the 3 worked and when you plugged in the 4th speaker to the other side and it shut everything down (like bd suggested) then I would say you have a problem with that speaker.
Offline dc7432
« Reply #5 on: September 17, 2014, 05:19:29 pm »
The left front wasn't working / shut off the volume when connected. I disconnected the LF speaker wire at the radio and used the wires from the LR radio to the LF speaker and it worked, so not the speaker. I connected the RF speaker with the other set of radio wires and off it went. I will check all the connects thanks for the input.
Offline dc7432
« Reply #6 on: September 18, 2014, 03:48:59 pm »
Reconnected all wiring no change speakers go out after around 5 minutes could the radio be bad?
« Reply #7 on: September 18, 2014, 04:02:31 pm »
Other than the sub are you powering all speakers directly from the head unit or using an amp?
Offline jaredts
« Reply #8 on: September 18, 2014, 04:07:22 pm »
What impedance speakers are you using?  A better question is whether or not you have checked that they are compatible with your head unit?
Offline dc7432
« Reply #9 on: September 18, 2014, 07:05:32 pm »
I have a 600 w kicker amp plus the base (600w) and the speakers are connects through the standard wires that come with the radio. The speakers are 4 ohm
« Reply #10 on: September 22, 2014, 08:03:39 am »
     Have you tried to leave the left front speaker disconnected to see if it will work for any length of time ?  More than 5 min say.
Offline frotosride
    • WFO CONCEPTS
« Reply #11 on: September 22, 2014, 09:01:31 pm »
That channel is grounding out somehow. Pioneer has a built in safety feature that cuts the highs and mids when any of the main  4 channels are grounded. This is to prevent burning up the Moser amplifier. You may have a blown voice coil...or as I have done many a times..your +\- wire is grounding on the dash somewhere.
