Author Topic: need a step by step for replacing ignition cylinder  (Read 5918 times)
Offline 84k10355ci
« on: September 17, 2014, 11:27:20 pm »
Hi guys I'm not having much luck on what it takes to replace an ignition cylinder in my 84 k10. Could someone please give me a good step by step on what I need to do to replace it? Pictures of the process would also be extremely appreciated. And it a not really electrical related but my column is very sloppy it bangs up and down, while I'm in there doing the cylinder is there something I can tighten to stop the column from being so sloppy? Thanks guys
Re: need a step by step for replacing ignition cylinder
« Reply #1 on: September 17, 2014, 11:59:30 pm »
Ignition switch replacement is fully explained on page 258 (3B4-19) of the 1986 Service Manual.  (Note that 1985 and 1986 procedures are identical).
this help go to page 255
« Reply #2 on: September 18, 2014, 01:24:20 am »
"How To: Fixing a Sloppy GM Tilt Column" should answer most of your questions.
Offline 84k10355ci
« Reply #3 on: September 18, 2014, 08:45:24 am »
This is by far the most helpful forum I've ever been on! I can't thank you guys enough these pages will definitely help me!
