Which one to use?
Topic: Which one to use? (Read 9964 times)
Blazin
Blazin new trails!
Which one to use?
September 20, 2014, 06:32:23 am »
Yellow snow is in need of a heart transplant do to 30 lbs. compression in # 4 & about 10 lbs. in #7 cylinders. Get through the winter with a used motor while I rebuild the one in it, or another one.
I have a known 85 305 out of a Blazer that has been sitting in the row of parts rigs behind the shop for 5 or 6 years. It has 180 to 185 lbs. compression across 8 cylinders, ran good when I parked it back there, little fuel down the carb, & it ran good a few days ago before I cut the truck up for scrap. I also have a GM reman 350 that has 120 to 155 lbs. across 8 cylinders out of a recently acquired 83 K 10 that is being cut up as well. Drove it to the shop a few weeks back, ran like crap. Pretty sure the reason for that is the Edeljunk carb that's on it. Thinking about swapping a different carb on today, & hearing it run before my final decision is made.
Just curious of input as to which one you guys think I should use?
zieg85
Re: Which one to use?
September 20, 2014, 07:37:12 am »
No brainer for me, go with the known 85 305 out of a Blazer. Toss it in and only rebuild yellows if the 305 isn't up to the task
Blazin
Blazin new trails!
September 20, 2014, 07:56:57 am »
Thats what I am leaning toward.
The two most reliable small blocks I have ever own have been 305s.
zieg85
September 20, 2014, 08:12:21 am »
Back in the day they were either really good or they flat cam'd out and were problematic. But I've had a few that were very smooth
Stewart G Griffin
September 20, 2014, 08:54:19 am »
My 305 is from a 78 malibu and still runs fine and has never been rebuilt. People rag on 305s but they are dependable and have no problems scooting the truck (when empty) along at 65, 75 etc. mph.
Blazin
Blazin new trails!
September 20, 2014, 08:33:44 pm »
Yellow Snow is rarely empty, & plows snow too!
fitz
September 20, 2014, 09:04:14 pm »
Didn't the motor in yellow snow give you trouble breaking harmonic balancer bolts last winter?
I'd put a carb on the GM rebuilt 350 and see how it runs.
If it runs good, I'd put it in yellow snow and call it a day.
I know anything can be rebuilt, but I'd be nervous about why the harmonic balancer was acting up last year.
Blazin
Blazin new trails!
September 20, 2014, 09:34:15 pm »
I yanked it last winter & put a brand new crank & bearings in. I should have done a complete rebuild then! Trying to get it together quick before the next storm. The old crank got tossed in the scrap pile!
Blazin
Blazin new trails!
September 21, 2014, 07:44:23 pm »
Took the Edeljunk carb off, & threw it across the yard ( that felt really good ), pulled the plugs, cleaned them up. Put the quadrajet off the 305 outa the Blazer. The 350 run very well actually.
fitz
September 21, 2014, 10:16:28 pm »
If the 350 is running good, I vote that you use that motor.
When I think of a 305 It brings back thoughts of the soft cams from the late 70's 305's as Zieg pointed out.
roundhouse
Which one to use?
September 22, 2014, 06:51:22 am »
The 305 is great for demo derby cars
Little wimpy for a plow truck
A 305 will run for over 30 minutes with no coolant
Blazin
Blazin new trails!
September 22, 2014, 07:18:15 pm »
I've had 305s in trucks before. Like I said, the two most reliable small blocks I have ever had were 305s.
On that note, I think I sold the 305 today. Plus have a lead on a 30,000 mile 350!
Decisions, decisions!!
frotosride
September 22, 2014, 08:52:16 pm »
Drop the 305 in until u at least re- ring the 350 and maybe a good can to make the torque u need for the plowing adventures. At least this way the truck can stay on the road as long as you need it to the get the 350 up to snuff for the power you need to move white dirt. Torque is what you need even if you gotta wait a little while to get it. Granted sealing an engine in the dead of winter sucks. But its not like you gotta worry not much electrical...so easy beer night swap.
Blazin
Blazin new trails!
September 22, 2014, 09:58:50 pm »
The motor thats in Yellow Snow will get rebuilt. It has a brand new crank in it. Its been down all summer, been running my 87 V20, & my Cherokee. What gets put in will stay in till next fall as long as it stays together that long!
frotosride
September 23, 2014, 03:12:57 pm »
305 hands down... U got low gear aka auto torque multiplier
Which one to use?
