Author Topic: Wipers won't turn off 1985  (Read 41614 times)
Offline Fairlane514
« on: September 24, 2014, 09:18:11 pm »
85 Blazer….new wiper motor, new wiper switch.  As soon as I turn the key to the on position the wipers come on. It will go from Lo to Hi, but refuses to turn off.
I do have intermittent wipers and I have bypassed the delay or pulse module with the same result. I have removed the two wire plug from the park switch and it keeps running.
The wiper motor was not installed when I bought the Blazer but it was brand new in a box. The rubber isolators were also missing, but I tracked some down and mounted it. There is no ground strap or loop or anything else grounding the motor to the body. I don't know if this is correct and I need to ground it somehow. I checked for continuity on the two ground wires from the lower harness that powers the motor and they tested good.
I have also plugged in the old wiper switch and it does the same thing. Before replacing the wiper switch, the wiper motor would function normally , but without a delay or pulse, just Lo and Hi. Now that I have replaced the wiper switch they come on with the key and won't turn off. It is the correct switch for a tilt column and delay wipers.
I did do a search and some had very close problems to mine, but not exact.
Re: Wipers won't turn off 1985
« Reply #1 on: September 24, 2014, 09:28:49 pm »
The wiper switch provides ground to the w/w motor to control motor speed.
1. 'White is B+ (12 volts with ignition ON)
2. Gray is Lo (when grounded by the dash switch)
3. Purple is High (when grounded by the dash switch)
4. Black/Light Blue is Park and grounds gray (Lo) through the park switch when the dash switch is in the OFF position
Sounds as though you might have a gray control wire grounding somewhere between the switch and the motor, or inside the motor assembly.  Does it continue to run if you unplug the dash switch?
Offline Fairlane514
« Reply #2 on: September 24, 2014, 09:38:53 pm »
When I unplug the dash switch it stops.
I did use a test light on the lower power supply plug with the three wires (white, gray and purple) while it was running. The white was power with a bright test light, the gray was a very dim test light in Lo, and I didn't test it in Hi.
« Last Edit: September 24, 2014, 09:43:13 pm by Fairlane514 »
« Reply #3 on: September 24, 2014, 11:38:29 pm »
If you unplug the wiper switch and ground gray with ignition on, the w/w motor should run at low speed; ground the purple and it should run at high speed; ground the blk/lt blu and it should park.  Does it?
Offline Fairlane514
« Reply #4 on: September 25, 2014, 09:02:50 am »
Yes, it does exactly as you describe.
« Reply #5 on: September 25, 2014, 09:23:55 am »
Assuming the delay module is still removed from the circuit, it sounds like a switch problem.
Because of something you posted earlier, physically remove, clean and verify proper grounding of the black wire coming from the w/w switch harness.  It should ground near the e-brake pedal.
And, install a ground jumper between the w/w motor case and cab ground - this should have no electrical effect except to help shield EMI from interfering with radio reception.
« Last Edit: September 25, 2014, 09:56:40 am by bd »
Offline Fairlane514
« Reply #6 on: September 25, 2014, 09:28:51 am »
Ok, Thanks …..I will check the grounds
Offline Fairlane514
« Reply #7 on: September 25, 2014, 09:48:31 am »
The solid black wire from the harness goes into the large bundle of wires and then routes behind the fuse block. I don't see a ground near the E-brake pedal. I also placed a ground wire into the black wire "pin" location and no change. From the motor side, a ground wire made no difference.
My old w/w switch acts the same when I plug it in. Maybe I have two bad switches….
Offline blazing816
« Reply #8 on: September 25, 2014, 09:49:22 am »
Post what you find on here please, because I am curious. I have wippers that will shut off but when they want to, sometimes I have to go from high and swtich it fast to off to stop them, or go the washer juice to get them to stop....really annoying.
Offline Fairlane514
« Reply #9 on: September 25, 2014, 10:12:49 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=10154.msg71196#msg71196
 I did the test on this diagram. Mine would not start when I added the 12v at the '19' position.
Then i did a continuity check of the 17 and 18 wires and they were good to the plug that connects to the w/w switch harness from the steering column.
« Last Edit: September 25, 2014, 10:14:54 am by Fairlane514 »
« Reply #10 on: September 25, 2014, 10:28:30 am »
If all you connected to the motor was 12 v to #19, it shouldn't run.  That just indicates the motor isn't grounding internally.
I hesitate at two switches being bad, but it's not unprecedented.  Replace the delay module and re-verify you have the correct switch.
Offline Fairlane514
« Reply #11 on: September 25, 2014, 10:35:24 am »
Verified new switch with old both by visual comparison and plugging back in the delay module. The wires are in the exact same position and color as the old switch.
« Reply #12 on: September 25, 2014, 10:52:56 am »
How is the ground between the cab and frame?
Offline Fairlane514
« Reply #13 on: September 25, 2014, 10:56:13 am »
I have the 10 gauge wire from the battery ground cable bolted to the core support.  Grounds for stereo etc seem good from inside the cab.
« Reply #14 on: September 25, 2014, 11:08:50 am »
Body to battery is important but to frame is equally important.  I've had weird things not work and it always was a bad ground usually due to an engine change, cab fire wall to back of head braided wire ground either missing or not tightened up
