Author Topic: 1984 1/2 ton pick up with 6.2L engine  (Read 12264 times)
Offline cheryldbob
« on: October 03, 2014, 10:36:28 am »
 I am wanting to change all the belts on this 6.2L engine from factory to a single serpentine or combination serpentine and "V". As anyone familiar with this set up knows the alternator and A/C belts are constantly stretching and vibrating at low RPM. Maybe there is a conversion kit available or even a supplier of additional idler pulleys or tensioners.
Re: 1984 1/2 ton pick up with 6.2L engine
« Reply #1 on: October 09, 2014, 08:03:51 pm »
The later model 6.5L's are all that had the serpentine setup, the components swapped around a little.  Not sure what you are asking on the other part.
« Reply #2 on: November 04, 2014, 11:49:25 pm »
wish i would of seen this a couple weeks ago. i had a 6.5 that was locked up would of gave you all the front parts but she went to the junkyard to clean up a little around the yard :(
