Author Topic: Loose steering  (Read 5358 times)
Offline fourtonnemantis
Loose steering
« on: October 04, 2014, 05:32:05 pm »
Hi everyone! I've got a 79 K10. Truck drives very nice, but recently it's started to have an issue: when I make a turn, and start to turn the wheel to straighten it out, once it's nearly straight, it continues to turn, just slightly. Then without my input, it'll suddely straighten out with a little jerk, a moment later.  The truck drives well in a straight line, doesn't wander. I've crawled all over, and can't find any play in the tie rid ends, or ball joints. The only thing I noticed is a very small amount of play in the shaft coming out of the steering box. IE, the shaft the pitman arm is splined to. It has 1/16-1/8" of play up and down in the box. Not side to side.
My question: is this the cause of my problem? If so, can the steering box be repaired? Or do I need to replace it? OR is there something else I should look for? I looked for cracked springs and cracks around the steering box. Couldn't find anything.
Thanks!
Re: Loose steering
« Reply #1 on: October 04, 2014, 07:49:20 pm »
my brother was driving my 79 one time had a similar problem but mine was the three bolts holding the steering arm on, well two were broke. i would get a helper and with with truck off have them turn the wheel in both directions and see what moves without effecting other parts
Offline Don5
Re: Loose steering
« Reply #2 on: October 04, 2014, 08:04:59 pm »
I was going to post the same answer but you beat me to it.  ;D I did the same thing with mine also. It did the same thing as four describes. Good luck.
Re: Loose steering
« Reply #3 on: October 05, 2014, 07:58:32 am »
Thanks. I've had a friend in the truck turning the wheels back and forth while I check everything out. But all I could find was just a slight movement in the shaft coming out of the steering box. Everything else is tight.
Offline illinoisk30
Re: Loose steering
« Reply #4 on: October 05, 2014, 08:49:26 am »
You may want to check your axle shaft u-joints. If they are seized up it would affect your steering. Most of the time if these are bad there is a popping sound from them trying to move in the direction they need to go. If there is no grease zerk on them they could be factory. Just a thought.
1977 Chevy K30 DRW 400 TH400
1978 GMC K35 SRW 454 TH400
1979 GMC K35 SRW 400 TH400
1980 Chevy K30 SRW 350 SM465
