Author Topic: '05 2500HD 4x4 - Transfer case questions  (Read 4294 times)
Offline Jason S
« on: October 13, 2014, 06:46:51 pm »
I know it's not 73-87 (91), but it is a Chevy truck...
2005 Chevrolet 2500HD, 6.0L, NV4500 and NP261HD transfer case. There's roughly 90,000 miles on it; mostly highway miles, many pulling a heavy trailer.
Since new, there has always been a bit of noise from the transmission. However, fairly recently there is more noise and I think it's coming from the transfer case and through the t-case shifter.
When going down the highway, it might start making the noise and then I'll let off the foot feed for a moment and the noise will quite down some. Also, I can place light pressure on the t-case shifter, moving it to either detent and the noise subsides.
With job relocation last winter and house hunting and 3 months of back and forth driving, I did a whole lot more driving in 4 wheel drive. Shift on the fly worked fine then. Somewhere along the way, I have lost shift on the fly.  I can shift into 4-hi from a standstill, but it wants to grind if there is forward motion.
I haven't driven the truck much since we finally got moved back in March.  I did notice with the last oil change (this spring) that when I turned the front drive shaft there was a clicking/ratcheting noise coming from within the t-case.
I've changed the fluids in the transmission and t-case within recommended intervals.
I've read about the 'Pump Rub' issue with these cases, I don't know if these issues are related to pump rub or if there is something else that may be the problem or if it's a combination of issues.
If anyone else has had experience or knowledge about this, I'd really appreciate input.
Offline Jason S
Re: '05 2500HD 4x4 - Transfer case questions
« Reply #1 on: November 19, 2014, 10:10:54 am »
Just to update...  The NV261 has pump rub issues and mine was no exception.  The pump had moved back rubbing the back of the case, the movement allowed the mainshaft retainer snap ring to waller out it's groove in the back of the case and the movement was eating into the range fork. Additionally, bushing in rear of case spun and wore into the driveshaft yoke.
So all is repaired and back together and it is probably the quietiest it's ever been.
Offline Kren420
  • 1986 C10 Silverado
« Reply #2 on: November 19, 2014, 01:24:38 pm »
Glad you got it figured out and thanks for keeping us updated!
