Engine/Drivetrain
Rear gears
Topic: Rear gears (Read 12716 times)
Ds2014
Rear gears
October 14, 2014, 08:16:16 pm »
I have the stock rear in my 81 step side. I have a 10.5:1 small block 408. How deep should I go with the turbo 350? I was thinking 3.42?
rich weyand
Re: Rear gears
October 14, 2014, 08:22:19 pm »
What tire are you running?
pratherjoe
Re: Rear gears
October 14, 2014, 11:24:41 pm »
http://www.competitiondiesel.com/Phil/bg/
This chart will show rpm's vs mph
Using Tapatalk
zieg85
Re: Rear gears
October 14, 2014, 11:37:00 pm »
Stall speed or stock converter, cam rpm range and type of driving are all considerations for your choice.
Ds2014
Re: Rear gears
October 15, 2014, 11:24:48 am »
Street driven 2800 stall 292/292 cam
Ds2014
Re: Rear gears
October 15, 2014, 12:45:23 pm »
Right now I have 31 10.50
zieg85
Re: Rear gears
October 15, 2014, 12:59:26 pm »
Around town or highway? What gears do you currently have? How does the truck perform now?
rich weyand
Re: Rear gears
October 15, 2014, 01:39:47 pm »
I wouldn't go to 3.42 with 31" tires. That 3.73 on there is like a 3.49:1 with those tires. A 3.42 would be like a 3.2:1.
Ds2014
Re: Rear gears
October 15, 2014, 07:00:42 pm »
Right now I can do a burn out at 45 mph
Ds2014
Re: Rear gears
October 15, 2014, 07:01:59 pm »
I am getting 17" rims and a 28 inch tire
Ds2014
Re: Rear gears
October 15, 2014, 07:03:25 pm »
I have 2.73
zieg85
Re: Rear gears
October 15, 2014, 07:23:21 pm »
If it were me I'd leave well enough alone then
Ds2014
Re: Rear gears
Reply #12 on:
October 15, 2014, 07:58:17 pm »
No posi tho. I thought about just putting a posi and leaving stock or going with 3.08
zieg85
Re: Rear gears
Reply #13 on:
October 15, 2014, 08:03:16 pm »
I mis-read, with 2.73 I would jump up to a 3.42. When I replied earlier I thought it said 3.73. A bump to 3.08 would barely be noticeable.
zieg85
Re: Rear gears
Reply #14 on:
October 15, 2014, 08:06:28 pm »
Limited slip of some sort is always a good thing, just make sure you know what it will do and get use to it. I've had more than my share my back end passing me, luckily it was on the track and nothing happened except a little embarrassment.
Engine/Drivetrain
Rear gears
