Author Topic: Lowering the truck  (Read 8518 times)
Offline Chisholmcody
Lowering the truck
« on: October 16, 2014, 04:55:37 pm »
So I was wondering how this all works.
So if I get 2in drop springs/coils in the front do I have to get the 2in drop spindles too or can I use the stock ones?
Also is it true that if I get the drop shackles (universal 2in-4in drop from advanced auto)for the leaf springs do I have to cut a notch in the bed frame?
And do I have to get drop shocks or can I get by with the stock ones for now (recently replaced)
Offline frotosride
    • WFO CONCEPTS
Re: Lowering the truck
« Reply #1 on: October 16, 2014, 07:09:32 pm »
OK, where to start... Coils and spindels. If you get the 2" drop coils/springs it will lower the front by 2" if you also add the 2" drop spindles you will have successfully lowered the front end 4" maybe more due to the design of the coil springs that you use and how they mount.
As for the notching of the frame...well if your truck is still at factory ride height you can surely get away with 4" drop without notching the frame. If the truck is already lowered then you have to find out how much and add the to whatever you do. It's really as simple as finding the lowest part of the frame and using a tape measure to determine the amount of room you have between the axels. Account for around3- 4" up travel and check for contact with a little math. Good luck!
Oh almost forgot.. As for the shocks.. Its a little more involved. There are several fa tors but to keep it simple and easy, to me one off the rear and one off the front (they are usually different lengths). If the shocks are not gas charged you will have to pull it up to its highest point. Now measure that length and rod and add it to the amount you want to lower the truck. Now measure the length of the shocks body. You will likely find that the piston will bottom out within a few inches of down travel. This will cause a rough ride and surely damage the shock. You may get away with a simple 2" drop and the original shocks until that first big bump! So play it safe and get shocks designed for the amount of drop you would like
Lowering the truck
« Reply #2 on: October 16, 2014, 08:30:51 pm »
Ok thanks for the info helps clear up a lot
Offline 78BIG-TEN
« Reply #3 on: October 17, 2014, 08:42:48 am »
I installed the BellTech 3\4 drop.Rear came with front spring hangers and longer shackles and was supposed to notch a bed cross beam.I didn't want to do that so I modified shackles to clear the bed.Lost about 1\2 of drop.Bear in mind that using this kit changed pinion angle dramatically
« Reply #4 on: October 17, 2014, 03:05:57 pm »
This may seem like a dumb question but is changing the pinion angle bad?
« Reply #5 on: November 24, 2014, 02:16:54 pm »
If it isn't set to the proper angle it will eat up the u-joints
« Reply #6 on: November 25, 2014, 02:18:29 am »
Whats a bad angle and how do you measure it?
« Reply #7 on: November 25, 2014, 09:41:34 am »
You will need an angle finder to measure it.  And you would get the angle of the trans output shaft and the angle of the rearend yoke and subtract the 2 to get the angle.
You want the pinion angle to be between 3-4.5 degrees on a street car.
« Reply #8 on: December 01, 2014, 12:58:18 am »
Ok thanks
