Author Topic: 83 K10 short box lifted 38.5 bloggers clutch problems.  (Read 7014 times)
Offline Hoov41
« on: October 16, 2014, 07:59:29 pm »
So I am the new guy here. I just bought an 83 Chevy k10 short box 4-6 inch suspension and 3 inch body. I replaced te clutch in it. I put a ceramic heavy duty clutch dual friction plate in it. The issue I'm having now is that I have to let the clutch pedal almost all the way out before it catches and it shakes something fierce. Before I swapped the clutch out it was catching about 2-3 inches off the floor board. The reason k changed it was because when it got hot it wouldn't go into gear when I was stopped. What type of clutch do you guys recommend to fix this issue or could it be something else? I have the 4 speed tranny with granny low. A 350 bored and stroked. Any info will help. Thanks.
83 Chevy K10 short box
38.5 superswamper TSLs
Re: 83 K10 short box lifted 38.5 bloggers clutch problems.
« Reply #1 on: October 16, 2014, 08:44:37 pm »
Did you have the flywheel resurfaced?  Did you get a new pressure plate and throw out bearing?  What is the gear ratio?
Offline Hoov41
« Reply #2 on: October 17, 2014, 05:24:31 am »
It has stock gearing. I didn't actually do the work myself. The guy said the flywheel was fine. I believe the pressure plate was included in the clutch kit. But what I'm thinking is that I got an aftermarket or "performance clutch" if you will so it neither stop or go there is no in between would that make sense?
Offline roundhouse
« Reply #3 on: October 17, 2014, 06:28:53 am »
Ceramic clutches are like that
Not slippage
They just grab and go
The issue of the pedal height should be adjustable unless you have a hydraulic linkage which was 1987 model only
Also the excessive body lift may be causing some issue
3" is a lot of body lift
How did you wind up with a ceramic clutch disc?
That's usually for race cars
« Last Edit: October 17, 2014, 06:32:08 am by roundhouse »
Offline Hoov41
« Reply #4 on: October 17, 2014, 08:14:00 am »
A guy recommended that I go with that because it is heavy duty and having big tires like that it would prolong the life and wear and tear. I just bought the truck as a project and I am still learning as I go.
« Reply #5 on: October 17, 2014, 10:20:55 am »
That is a lot of tire to get moving with typical stock 1/2 ton gearing.  I bet L is a useful gear in your case.
Offline Hoov41
« Reply #6 on: October 17, 2014, 11:23:07 am »
Oh heck yeah it is. Even going down hill. I wanna get like 4.56s to go in there. It's a work in progress.
Offline Engineer
« Reply #7 on: October 17, 2014, 06:48:40 pm »
I ran a metallic clutch in my sled puller. Metallic clutches are that way. I told everybody it was like having a toggle switch on the dash. The clutch was either in or out. No middle ground.
Now try imagining trying to take off with 30,000# of dead weight behind you. Lol.
One thing about it, in 15 years of sled pulling my 454 NEVER managed to make that clutch slip.....and that was with a stock 12" Borg & Beck pressure plate. When I tore my truck down to put a sintered iron disc in it my son put that old metallic clutch in his mud truck and beat on it some more.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline roundhouse
« Reply #8 on: October 17, 2014, 10:22:53 pm »
I wound up with an 18 wheeler that had a ceramic clutch
I hated it.   No way to slip it at all
Swapping in a normal stock clutch should cure it
Also have the flywheel resurfaced
Offline Hoov41
« Reply #9 on: October 18, 2014, 08:55:30 am »
Awesome. Thanks for all the input. Is there as good brand you guys would recommend? Also if I want to put 3/4 ton axles on it how much of a pain in the butt is it?
