Author Topic: Truck Dies  (Read 3936 times)
Offline theaddictedchef
Truck Dies
« on: October 17, 2014, 11:14:32 am »
Hi guys.  It's been a while since I've been on the forum.  I'm still trying to get my truck dialed in and I've run into some challenges.
Any time I turn the wheel to the right, moving or not, the engine dies.  I have looked and wiggled and pulled on every wire in there and can't find an exposed wire, or a loose wire.  Either from my firewall forward or behind, nor in the steering column.  Am I missing something?  Is this a distributor problem?  Is it a fuel problem?  I'm stuck and frustrated.
Thanks!
The Journey IS the Reward......
Offline jaredts
Re: Truck Dies
« Reply #1 on: October 17, 2014, 02:02:59 pm »
Assuming that it dies suddenly and doesn't just lower rpm's until it stalls:  hook a wire to ground and to 12v+ at the distributor and connect to voltmeter or test light.  See if you are losing voltage there.  Assuming that is good, hook a wire up to the distributor clamp and run it to battery negative.  See if that makes the problem go away.  It could be a faulty ground wire.
Re: Truck Dies
« Reply #2 on: October 17, 2014, 06:45:18 pm »
Thank you.  Trying that now.
