Author Topic: need to c/o electric speedometer to mechanical  (Read 3894 times)
Offline brian.potocki.7
« on: October 18, 2014, 12:00:04 pm »
I bought an 86 swb truck that has a granny 4speed in it an want to put a 5 speed n it but it has a the electric speedometer how can I convert it over to mechanical.
Offline jaredts
Re: need to c/o electric speedometer to mechanical
« Reply #1 on: October 18, 2014, 12:53:48 pm »
I don't think an '86 should have an electric speedometer.  Are you sure about that?  If it does you just need a cable driven speedometer, the cable, and the transmission set up with the proper driven gear.  A junkyard trip would probably be the best way to get set up.
« Reply #2 on: October 18, 2014, 03:15:13 pm »
The 4speed is mechanical its the 5 speed tranny that has electric speedometer.
« Reply #3 on: October 18, 2014, 03:35:11 pm »
Plus wandering if that 5 speed will hold up to my 350. It's pushing 330 hp an 420 torque!
« Reply #4 on: October 18, 2014, 03:43:35 pm »
Depends on what 5 speed you want..http://www.5speedtransmissions.com/68-87_chev_truck_5sp.html is what I am saving up for to put in my extended cab.
Offline jaredts
« Reply #5 on: October 18, 2014, 06:48:46 pm »
You need to tell us what 5 speed it is.  It usually involves replacing a reluctor ring with a drive gear and a driven gear and housing in place of the sensor.  Not terribly hard or expensive, but the amount of labor depends on the transmission.
« Reply #6 on: October 18, 2014, 07:09:49 pm »
Its a 1990-93 half ton chevy truck.  One is a 90 chevy sport it has a 350 n it.
« Reply #7 on: October 18, 2014, 07:26:17 pm »
The NV3500 will be fine if you don't beat on it.  It wasn't made to withstand what you want to put to it.
« Reply #8 on: October 18, 2014, 07:42:16 pm »
Well I'll get on it here an there but love to put the T56 in it if I can change the speedometer over to mechanical.  I found 3 of them n the pick a parts in t/a's.
