Author Topic: th400 shift kit issues and recommendations  (Read 2985 times)
Offline Liltroy
  • Newbie-doobie-doooo
« on: October 20, 2014, 10:09:35 am »
Hey guys, I recently installed a b&m transpack kit in my th400(375) trans and I'm having some issues and also have a few questions.
This is the first time Ive installed the transpak. I usually just install the lower priced shift kit and have never had any issues and am usually rewarded with really hard shifts. This time however, the shifts seem quick, but not really hard like they usually are with just the shift kit.
Since installing the transpak, I am having an issue with first gear. if I take off at full throttle, everything is good. But if I try to drive easy, the transmission immediately shifts to 2nd gear, even with my shifter in 1st. downshifting to first gear does nothing. the only thing that will forsce a 1st gear downshift is the detent solenoid kicking it down if I give it full throttle. I currently I have the transmission on an engine stand and I've already checked the governor for proper operation. I will also be pulling the valvebody to make sure the 1-2 shift valve isnt sticking because I didnt have this issue until I installed the transpak.
 Now for issue number 2. I noticed when installing the transpak that the instructions only told me to drill one hole in the seperator plate where as with the regular shift kit I always had to drill two holes. the other difference is that the shift kit tells you to remove the 2-3 accumulator spring and the transpak does not. Im wondering if the reason for these modifications missing is because of the stiffer pressure regulator spring with the transpak and the higher line pressure caused by this? Since I have to pull the valve body to check on the 1-2 sift valve anyway, I am wanting to remove the accumulator spring and drill the other hole in the seperator plate while I have it apart again but am worried about shat size to drive the holes since I now have increased line pressure due to the new regulator spring. Any input would be greatly appreciated. I've got a couple days before it all goes back together because I'm waiting on the new VB gaskets to get here. Help me out guys!  :D
" Horsepower is how fast you hit the wall. Torque is how far you move that wall. "
