Author Topic: Zinc  (Read 4513 times)
Offline Bitzer!
  • Smiles per gallon
Zinc
« on: October 22, 2014, 04:14:33 am »
Hi all,
A little quiet over this side of the pond, all work & no play.
A question for all you painters out there - If my chassis was blasted to bare metal and then zinc coated, what prep do I have to do to the coating before applying paint? Rub down, wipe, paint or can it just be wiped and painted?
Cheers in advance
Andy
1979 GMC CrewCab  C20 1t
Re: Zinc
« Reply #1 on: October 22, 2014, 05:34:19 am »
There are several styles of zinc and all should call out clearly the next step.  Most of the ones I've sprayed use an epoxy intermediate coat but I am in the industrial side.
Offline Engineer
Re: Zinc
« Reply #2 on: October 22, 2014, 07:15:01 am »
My '77 uses doors, fenders, and hood from a '91 Suburban. All are zinc galvanized. I sprayed DuPont Ful-Poxy primer on everything. Epoxy primers are compatible with zinc. There are a couple more but most automotive primers are not compatible with zinc.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
