Author Topic: Just bought a flip kit, ready to get er in but one problem...  (Read 19568 times)
Offline Sock
« on: October 22, 2014, 06:53:51 pm »
my jackstands don't go high enough to fully get the tires off of the ground..its a few inches short and im not sure where i can lift the truck other than the frame because i don't think i can lift it from the rear axle as that needs to be relaxed. its an 86 halfton longbox. any suggestions? not sure if putting wood in between would be too safe as the heads of my jackstands are V shaped.
thanks in advance
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: Just bought a flip kit, ready to get er in but one problem...
« Reply #1 on: October 22, 2014, 09:25:28 pm »
Dunnage is the term. It refers to the stacking or piling of material to make a solid base. To keep it simple just get some solid 6x6's x16" and make a solid base for the jack stands.
Offline Sock
« Reply #2 on: October 22, 2014, 09:44:34 pm »
Yeah i thought about that. then i saw the front leaf spring brackets were lower than the frame and looked fairly secure. im leaving it on jackstands overnight to see if they budge, and if they don't im going to go for it. i really need to invest in some larger jack stands  ::)
Offline Sock
« Reply #3 on: October 30, 2014, 10:42:55 pm »
Got er all back together, didn't put the shock extenders in yet but fairly happy with the result!
once i put the shock extenders in hopefully there will be enough clearance to where it wont bottom out.
Offline superman_m63
« Reply #4 on: November 02, 2014, 10:44:32 pm »
Can I ask what flip kit you used
Offline Sock
Offline Sock
« Reply #6 on: November 09, 2014, 06:01:15 pm »
flip kits all in but its nearly sitting on my frame...are my shocks just that bad? what shocks should i get? anybody else ever had this problem?
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #7 on: November 09, 2014, 11:38:49 pm »
You need to lose the bumps stops.
Nothing wrong with the shocks - shocks don't hold the vehicle up.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline Sock
« Reply #8 on: November 10, 2014, 05:26:46 pm »
keeping them on atm so my axle doesnt smash against the frame. couldn't i put stiffer shocks in or something?
Offline SkinnyG
« Reply #9 on: November 10, 2014, 08:26:25 pm »
Stiffer shocks (typical of lowering shocks) will ride stiffer, but do nothing to prevent the axle-on-frame contact.  Energy Suspension (among others) make an ultra-low profile bumpstop you could use (#9.9132, 3/8″ thick) if you ~get~ contact.
I have a c-notched frame, but do not run bumpstops at all.
Rumour is you likely will not need a notch with just a flip unless you intend to carry heavy stuff.
Offline Sock
« Reply #10 on: November 10, 2014, 10:55:17 pm »
alright, good to know. i don't plan on carrying anything in the back really maybe the occasional toolbox so i think i should be good. ill probably get some stiffer shocks though because these ones are real loose. any suggestions?
Offline SkinnyG
« Reply #11 on: November 10, 2014, 11:54:21 pm »
I'm running cheap Monroe blue.  KYB is better, and still reasonably affordable.  Gabriel is about on par with Monroe.
Offline Lowhoe775
« Reply #12 on: November 11, 2014, 08:40:39 pm »
Nice I would notch the frame for more axle travel. Some heavy duty shorter shocks I got some Gabriel guardian 82003. Ride smooth same length as the beltech drop nitro shocks. And are about 20.00 at autozone.
Offline Sock
« Reply #13 on: November 11, 2014, 09:22:50 pm »
don't have access to anything to notch the frame yet :( soon. won't shorter shocks make the frame closer to the axle?
Offline Lowhoe775
« Reply #14 on: November 11, 2014, 09:29:23 pm »
well when you get a chance and notch it. The shocks are only about 3 inches shorter than stocks. The shocks are not that strong where they pull on the axle, shocks only reduce the spring hop and also to reduce the impact of the road conditions.
