Author Topic: 1157 led stop lights  (Read 4573 times)
Offline Lit549
  • Banned
« on: November 01, 2014, 11:54:46 pm »
Bought some led lights that plug into stock socket and now my dashlights (gauges) all flash with turn signal,took out led bulbs and everything's fine..Will a load equalizer solve this,I thought those were only for blinkers blinking too fast after led install? Or do I just need a different flasher? 85 chevy c10,bulbs I'm trying to use are "pilot" brand 1157 led bulbs..
Re: 1157 led stop lights
« Reply #1 on: November 06, 2014, 07:48:35 pm »
The flasher has no bearing on this problem.  The bulbs are shorting the sockets' double-pin contacts or there's a floating ground.  Or, the bulbs could be mispackaged.  Make sure the 1157 LED bulbs each have two contacts, that they are properly indexed into the sockets, and that the sockets are properly grounded.
