Author Topic: source for pre-bent exhaust tubing  (Read 5487 times)
Offline 74stepside
« on: July 21, 2006, 10:31:00 pm »
i need the pieces that go from the collecter up and over the tranny crossmember,  is there anywhere that sells these pieces pre-bent?...i would rather not buy a whole kit because i already have the mufflers i want....
Offline roundedline
Re: source for pre-bent exhaust tubing
« Reply #1 on: July 22, 2006, 10:16:00 am »
If you are talking about prebent to fit headers, the answer is no.  Typically headers made for these trucks point down and extend below the crossmember.  Adding that many bends will not add to the flow, but...
You can get mandrel bent pieces that you can connect together to make your exhaust system.  www.flowmastermufflers.com, www.drgas.com to name a couple sell these..
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
