Author Topic: 1987 Chevy Misfiring when cold  (Read 15262 times)
Offline ericb
Re: 1987 Chevy Misfiring when cold
« Reply #15 on: November 18, 2014, 08:45:23 pm »
Rich-The ground strap between the passenger side head and firewall is in place.  I cleaned both these connection points extremely well.  I have not had a chance to check the specific vacuum line you referenced.  I will try and take a look at that.
Roundhouse-I have not tried unplugging the oxygen sensor.  I will also try that and see what happens.
Thanks for the suggestions.
Offline 87 Wrangler
« Reply #16 on: November 18, 2014, 10:58:15 pm »
Thanks Rich for the link!! My truck has surged for 25 years! Maybe I can finally fix it!
Offline 78BIG-TEN
« Reply #17 on: November 19, 2014, 09:03:54 am »
Only vacumn line on the back of tbi that I know of goes to the map.Usually a loss of vacumn here will cause engine to go rich.Tat being said I've seen carbon build up on the bottom of the tbi in the vacumn port causing a  restriction and even plugged up solid at pcv side
Offline ericb
« Reply #18 on: November 22, 2014, 12:15:34 pm »
Rich-I unplugged the oxygen sensor.  This didn't take care of the misfire.  I will try and look at that vacuum hose.  Thanks-Eric B
« Reply #19 on: November 22, 2014, 01:58:31 pm »
Holy Guacamole! You are way over thinking this. If you in fact have a cylinder misfire, isolate the affected cylinder and narrow it down from there.
If it's random and erratic then you need to do as BD said and check fuel integrator and block learn.
If you suspect it is a lean misfire, try misting a little carb clean in the tbi and see if it stops misfiring.
