Author Topic: Rocker Stud Screws wont stay put !  (Read 13401 times)
Re: Rocker Stud Screws wont stay put !
« Reply #15 on: November 20, 2014, 01:13:09 pm »
Via email from Mr. Gasket technical support on 11/20/14, "The Mr Gasket 1076 3/8-24 in. grade 8 studs would be torqued to 34 ft-lb with 30 wt oil."
So, you didn't overtighten the studs at 15 lb-ft.  The heads likely were already cracked and delivered that way.
Offline sawblade6
« Reply #16 on: November 20, 2014, 04:05:57 pm »
I appreciate the info.
So I need new heads?
84 C10 350/700R4
Semper Fi
« Reply #17 on: November 20, 2014, 06:13:05 pm »
As previously stated, the rocker stud holes penetrate the water jacket.  I know of no repair procedure that I could confidently recommend.  Hence, I recommend replacement.  Will the engine builder provide any assistance?
Offline sawblade6
« Reply #18 on: November 20, 2014, 09:57:02 pm »
Im still working with them.
I`ll post any updates. thank you for the assistance!
84 C10 350/700R4
Semper Fi
