Author Topic: radiator replacement  (Read 3321 times)
Offline dalefan613
« on: November 15, 2014, 09:24:00 pm »
I have a 1975 454 radiator started leaking today thinking of getting an aluminum one any suggestions
Re: radiator replacement
« Reply #1 on: November 15, 2014, 11:17:55 pm »
why? if you dont have a over heating problem then i dont see the point of aluminum
Offline LTZ C20
« Reply #2 on: November 16, 2014, 01:47:07 am »
Search around local radiator shops and just get it repaired. If it's the original steel radiator and it's a small leak then it should be easy to fix, I got mine completely cored and re sealed for pretty cheep and it works great.
LTZ Cheyenne C20
Offline roundhouse
« Reply #3 on: November 16, 2014, 07:18:26 am »
Local shop wanted $350 to recore our clogged up 1980 brass & copper rad
$120 for new plastic and aluminum one
Offline Engineer
« Reply #4 on: November 16, 2014, 09:11:50 am »
I bought a Delphi aluminum/plastic 4 core replacement for my 454.
The Delphi unit is only a 2 row but otherwise is identical to my factory brass unit. The core is still the same thickness, it just uses 2 tubes instead of 4.
The aluminum radiator is about 1/3 the weight of the brass radiator.
I think Autozone, et.al has these for $130~$170.
No more brass radiators for me, thanks. The weight savings alone is reason enough to go the aluminum route.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline dalefan613
« Reply #5 on: November 16, 2014, 12:00:08 pm »
going with the aluminum weight looks and cooling summers get hot out here and will be towing my ski boat the champion seems decent hopefully the make a shroud for my flex fan like to open hood at the local shows so looks count too
