Author Topic: Stupid, difficult electrical failure solved  (Read 4827 times)
Offline rich weyand
« on: November 23, 2014, 12:02:21 am »
Here's a strange problem.  It took a while to debug this one!
I was sitting in the truck with the engine running on a very cold day this week, waiting in a restaurant parking lot for the missus to join me for supper.  I had the heater blower running on LOW till the engine warmed up, then on MED, finally on HI.  And then it stopped, like it had been turned off.  All three speeds gone.
I waited until it warmed up a bit the next day to look at it.  Logic says it has to be something between the fusebox and the blower switch on the dash, or between the blower resistor on the firewall and the blower motor, including the blower motor itself and its connection to ground.
I performed various tests, and determined the following:
- Connecting the blower motor directly to battery positive, the blower motor fires up and runs just fine.  So the blower motor and its ground are OK.
- Taking the blower resistor connector off the firewall and injecting battery power into the blower motor contact, the blower runs just fine, so the harness between the blower motor resistor and the blower motor, including the arc-noise-suppression coil on the firewall, is fine.
- I replaced the heater fuse on general principles.  The old one looked like it might have been original with the truck.
- Pulling the instrument bezel and measuring the voltage at the blower motor switch, I had 0V, 13V, and 14.5V respectively with the ignition off, the ignition on, and the ignition on with the motor running.
- Jumpering the connector positions on the blower motor switch connector (LOW wire to MED wire, LOW wire to HI wire) made no difference.  No blower function.
WTH!  That is all of the elements common to all three speeds.
It's very uncommon, but it could be a wire failure.  I measured the resistance of each wire segment, and found that the wire from the blower resistor connector to the arc-noise-suppression coil was broken inside the insulation about an inch back from the blower resistor connector, where it made the bend from vertical to horizontal to go into the connector.
I had tested this in the second step above, but when I took the connector off and twisted it around 180 degrees to jumper battery power into it, the break reconnected.  When I twisted it back around to plug it back onto the blower resistor, it disconnected again.  I found that when I bent it a certain way, it would work, and when I bent it back, it would disconnect.
My surmise now is that when I got into the truck and it was cold, it was working OK, and as the truck warmed up, and the radiator electric fan started cycling while I was idling in the parking lot, the temperature change, plus the current through it when I switched to high, allowed the wire to move enough to disconnect, or blew out the final strand of wire remaining on a progressive failure.
I took another look at the connector between the blower motor resistor and the arc-noise-suppression coil.  This is a weatherproof connector maybe 8 inches straight up from the resistor connector, and a couple inches from the coil.  This weatherproof connector had the "bell" of the female connector pointed straight up.
So while it would shed most water, whatever water collected at the seam of the connector could work its way down into the connector, and into the insulation of the wire, and collect in the bottom of the wire, where it turned the corner.  And over decades it rotted the conductor inside the insulation.
How's that for a tough one to find!  Note that it is failure by design, and is an incipient failure whenever you have a weatherproof connector oriented to catch water instead of shed it.
Anyway, I put in a new wire.  And I redid the connection with a normal crimp female connector so there is a heat shrink on the male part of the connector that hangs down over the female to shed water instead of collect it.
I also took the opportunity of having the dash open to replace the existing, broken and marginally functional heater control assembly with a repro version from a mail-order supplier (plug and play, looks identical to the original).
The first photo is the fixed wiring.  I am pointing to the place where the wire broke internally.  The second photo is the broken wire.  It looks short because it is tipped toward the camera so you can see the bell of the female open at the top.  This wire is broken internally at the 90 degree corner at the bottom.
Offline LTZ C20
Re: Stupid, difficult electrical failure solved
« Reply #1 on: November 23, 2014, 01:39:05 am »
I just had a similar problem and had it fixed pretty quick. My blower would run then stop. If I wiggled the weatherproof connector right at the plug in on the blower motor it would work again. So using a jumper wire, I connect one end of jumper to the blower motor side and the other end into the female side. Wiggled at the motor, nothing. Wiggled at the plug end, starts working again. So all I did to fix it was cut the wire off about 3 inches up from the end, crimp on one of those  HEI distributor BAT/TACH single wire pigtails. They have the same size contacts as the blower motor plug but are bigger than a regular spade male/female connector. Eventually I would like to get a whole new wire from resistor to motor but for now it functions just fine like it used too. The break in the wire was right wire the wire meets the rubber body of the female weatherproof plug.
LTZ Cheyenne C20
