Author Topic: 78 lwb to swb (tub dimensions)  (Read 4774 times)
Offline cardar911
« on: November 25, 2014, 06:52:56 am »
Hi guys I know covered 100 times..
Got a 78 c20 lwb converting to a c10 swb.. so its 14inches off the frame before the diff and 4-6 after..
Now the question is the swb tub..these are hard to get around here so im going to chop to size.. I need to know how much to cut out of the lwb to make it swb.. I guess the same 14inches like the frame before the diff but how much after the diff and any total measurements..
Thanks in advance guys
Re: 78 lwb to swb (tub dimensions)
« Reply #1 on: November 25, 2014, 09:12:01 am »
Cutting down the frame:
http://www.73-87chevytrucks.com/lwb_to_swb.htm
I recommend using a different method of cutting though.  I would mark the 14" area an notch it like this:
I would use this a a guide: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7334.msg43642#msg43642
Cutting down the bed:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=26656.0
« Last Edit: April 19, 2024, 08:41:56 am by Captkaos »
Offline cardar911
« Reply #2 on: November 29, 2014, 02:44:11 am »
Very good write up indeed the motivation I need.. but the tub sizes arent detailed in these posts though
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #3 on: November 29, 2014, 12:39:40 pm »
14" is cut out behind the cab, so 14" will need to be cut out of the box between the front bulkhead and the fuel filler bump.  I cut 5" off the back of the frame as well.  Some cut 6".  My shortbox has 71" inside-to-inside of the stake pockets, so cut the difference out of the back.
I intended to shorten the longbox off mine, but I lucked out and found a shortbox locally for less than the cost of the replacement wheel arches I would have needed.
« Last Edit: November 29, 2014, 12:42:20 pm by SkinnyG »
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
« Reply #4 on: December 01, 2014, 10:35:16 pm »
The top link I posted describes the whole process with measurements.
