Author Topic: mechanical or vacuum secondries  (Read 14215 times)
Offline SUX2BU99
Re: Oh Well!
« Reply #15 on: January 03, 2007, 11:31:00 am »
They did. Even put 800's on the 302 in the 1st-gen Z/28s. Doesn't mean they were kinda overcarbed though. Not sure why GM did that on quite a few of their motors but they did. I would think driveability would suffer from it. But that's the beauty of a spead-bore:  small primaries for good throttle response around town and part throttle, and big secondaries to draw a lot of air in at WOT. Problem is that stumble when you stomp on it and the big secondaries open and the motor can't use all that available air, plus the resultant slow down in airflow velocity when the big ports open up that the motor can't use yet since it's still at low revs.
Offline roundedline
Re: Oh Well!
« Reply #16 on: January 03, 2007, 01:44:00 pm »
Quote:
And I thought that Chevrolet put 750 Quadrajets on 350's from the factory,Humm
Vaccum carbs...  It only gave as much gas as the engine needed.  It can only pull in so much fuel.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
