Author Topic: mechanical or vacuum secondries  (Read 14214 times)
Offline daman02
« on: June 07, 2006, 10:43:00 pm »
I'll start off by tellin what i have.  I got a 350 .060 over flat top pistons, 480 lift cam 284 adv. duration int/exh, vortec heads, air gap intake.  Now, i currently have a street avenger 670 w/ vacuum secondaries on it but i was told by a very well respected engine builder that for my application i should get rid of that carb and get a mechanical secondary barry grant demon carburetor.  The truck does get driven regularly but i want the most performance i can get.  All input will be appreciated.
'86 C10 Silverado 350 with 700r4 and 2500 stall
Dropped 2" in front and 2" in rear but soon to b 4" in rear
18x10 wheels with 295/45 18 tires
Offline DnStClr
Re: mechanical or vacuum secondries
« Reply #1 on: June 17, 2006, 06:11:00 pm »
Just a guess, but I think he's referring to the mech. secondaries ability to open the throttle plates more efficiently than a vaccum operated secondaries, dont you think? Those Demon carbs are pricey, but when you're building power like your engine does, you don't want the carb to be the weak link in puttin the torque to the ground...
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline 1976Scottsdale
« Reply #2 on: June 19, 2006, 07:58:00 pm »
The Mechanical secondary carb is nice because the engine does not regulate the secondaries by vacuum.  I run a Q-jet(V secondaries I think) and it is pretty nice, but I have done away with most of the linkage and the secondaries open pretty much whenever I want them to, that is nice in engines like ours because they require more fuel.  Get the mech carb.
Offline daman02
« Reply #3 on: June 20, 2006, 08:31:00 am »
well i'm gettin a speed demon so my street avenger is for sale now
Offline RSBAD454
« Reply #4 on: June 28, 2006, 11:41:00 pm »
Well, if you have an auto tranny....a Vacuum secondary is recommened. Vacuum secondaries are great for heavier vehicles with auto trannies. I have a holley 780 vacuum secondary and it works great. You might hurt your performance by using a mechanical....vauum secondaries only open upon demand of the motor.
Toys are my game
http://
Offline joesgarage71
  • Wrench
« Reply #5 on: October 18, 2006, 09:48:00 am »
I agree with RSBad454, I have a stout 454 in a heavy Automatic car and wouldn't use anything but a vac carb.I use a Holley on the car and have Quadrajets on my trucks.When there tuned right there awesome.Alot less gas useage.
Steve
Offline Leadfoot
carb
« Reply #6 on: October 19, 2006, 07:51:00 am »
8)
Edited by: Leadfoot at: 10/24/06 5:07 pm
Offline roundedline
Re: carb
« Reply #7 on: October 19, 2006, 12:58:00 pm »
Offline Leadfoot
NO
« Reply #8 on: October 19, 2006, 02:54:00 pm »
Aaarghhh..8)
Edited by: Leadfoot at: 10/24/06 5:06 pm
  • Wrench
Oh Well!
« Reply #9 on: October 19, 2006, 08:22:00 pm »
Oh Well!
Offline daman02
Re: Oh Well!
« Reply #10 on: October 23, 2006, 07:24:00 pm »
wow since i seen that this post is revived i'll tell you that i will have 3.73 gears with a 2500 stall.  and i am looking for more performance than gas useage.
  • Wrench
Re: Oh Well!
« Reply #11 on: November 09, 2006, 09:35:00 pm »
If you can barrow a 750 vac or double pumper holley from a friend and try it for a day you will like it.Your 670 is alittle small for the engine you have.
Steve
Offline stepside454
Re: Oh Well!
« Reply #12 on: November 22, 2006, 09:38:00 am »
670 cfm is enough cfm for that motor to about 6500 RPMs , especially with the large plenum on that airgap intake. I woulda kept it on there myself.
Offline SUX2BU99
Re: Oh Well!
« Reply #13 on: December 14, 2006, 03:42:00 pm »
^ Yeah, overcarbing it can lead to more performance disappointments, and mech. secondaries even more so. You might find your throttle response is lacking and too soft on the low-end.  Do you like it to feel responsive and torquey around town or boggy and then it tear up the road when the revs are high?
  • Wrench
Re: Oh Well!
« Reply #14 on: December 14, 2006, 09:48:00 pm »
And I thought that Chevrolet put 750 Quadrajets on 350's from the factory,Humm
