Author Topic: Body mount replacement  (Read 25840 times)
Offline LTZ C20
Re: Body mount replacement
« Reply #15 on: December 13, 2014, 04:13:09 pm »
No the summit sets do not come with bolts. You can check the site store and see if Chris sells bolt kits. If not try a restoration site such as Classic/industries. You can also take the bolts to the local hardware store and just get new ones, make sure to get grade 8 bolts, they are the strongest. The last thing you want is the cab braking loose from the frame in an accident or some thing.
« Last Edit: December 13, 2014, 09:08:30 pm by Captkaos »
LTZ Cheyenne C20
Offline mmanship
« Reply #16 on: July 07, 2020, 03:56:03 pm »
Do other years of truck"s body mounts interchange with the 1987 or is the 87 a one of one year?
« Reply #17 on: July 07, 2020, 06:31:13 pm »
Depends on if it's 2 or 4WD 73-80 or 81- up. Just order them for your application.
Offline Mike81K10
« Reply #18 on: July 09, 2020, 03:28:53 pm »
On my thread 81 K10 Cab Bushings R&R your will see info on me changing out the cab and radiator support bushings with the Poly ones and I could not find them with the hardware. I bought stainless steel bolts (they were a little longer than needed - so I cut them to length) and stainless washers to solve the rust problem.
