Author Topic: Floord Dimmer and Steering column hazard switch relocate - Easy or hard?  (Read 4467 times)
Offline WhtWlf80120
Vehicle: '81 Chevy C20 Standard Cab, 4Speed Transmission
Having issues with both the floor dimmer switch, and the steering column hazard switch.
Been thinking on putting both on a toggle switch. Did not know if someone else has attempted this or not?
Basically I know the floor switch is a 3-wire set up, so the idea on putting a toggle switch should work.
Anyone who has done it, if you could enlighten me, Thanks in advance.
Offline roundhouse
Re: Floord Dimmer and Steering column hazard switch relocate - Easy or hard?
« Reply #1 on: December 01, 2014, 06:30:18 pm »
Way Easier to just replace the switches with what is already there
The hazard switch is about $25 and isn't hard to replace
Although you do have to pull the steering wheel
Dimmer switch is just two screws
« Reply #2 on: December 01, 2014, 07:16:16 pm »
I haven't ever done that.  I usually just fix what is broken.
Offline FlatBlack77
« Reply #3 on: December 01, 2014, 10:22:47 pm »
i had trouble with my dimmer switch aswell and just replaced it with a spare i had lying around. or you can get a new one from an auto parts store pretty cheap.
and its a 5 minute fix
