Author Topic: Radiator Brackets  (Read 18418 times)
Offline bmax87
Radiator Brackets
« on: December 01, 2014, 03:10:34 pm »
I'm trying to find out where to buy the top brackets for a 4 row radiator. I took out a 2 row along with the original 350 and went back with a 454 and 4 row, I don't have the 2 row brackets to see if they will fit or not, truck is an 87 and the radiator came out of a 90 suburban. I called   and not much help on finding out if the 2 row brackets listed for 305 and 350 will work or not. Thanks.
Re: Radiator Brackets
« Reply #1 on: December 01, 2014, 04:56:36 pm »
On my 85 and a recent 86 I parted out the top mount is a solid tin piece that incorporates the brackets that the radiator is clamped down and the fan shroud is attached to.
« Reply #2 on: December 01, 2014, 10:03:55 pm »
The tank thickness is the same for the 350/350, so the radiator should be the same.  The only one I know of that is different for a 81-87 is the Diesel radiator which is longer.
this is the diesel:
Gas is like this.  the 2 holes in the core support at the bottom of the picture are where the diesel goes.
« Reply #3 on: December 02, 2014, 08:12:28 pm »
I made my own for Yellow Snow out of a couple pieces of flat stock. Drilled hols to match the ones in the core support. Then bent & welded the pieces to wrap over top of the radiator. I ended up using a mid 70s fan shroud. Drilled holes in it, & the over hang of the brackets, & holes in the bottom to match the stock mounting. Used U nuts on the bottom, 1/4x20 nuts & bolts on top.
Offline jetmech
« Reply #4 on: December 03, 2014, 08:05:58 pm »
The 454 radiator top mount, like zieg85 said, is a one piece top that is still available. Its the 350 four row mounts that I can't seem to find. They look like the diesel ones in the pic. Not sure if they are exactly the same.
'86 Sub and '86 SWB C-10
1990 454 SS
