Author Topic: 87 V30 frame off. Cummins?  (Read 16345 times)
Offline flips87c30
« on: December 01, 2014, 03:53:02 pm »
Finally starting my truck build. Old frame was cracked. Got a new frame. Going to beef it up as much as possible.
The 454 is getting tired and for my purposes I would really like a diesel so ive been looking into a cummins 6bt swap.
Here is where Im at so far. Cut and lifted the dump bed off the frame. I am loving my shop crane right now.
87 v30 duelly dump truck 454, th400, np205, dana 60/14 bolt, warn hubs, gmt800 mirrors and LEDs all around the bed.
Offline Engineer
Re: 87 V30 frame off. Cummins?
« Reply #1 on: December 03, 2014, 07:26:41 am »
I thought I responded this thread. Why was my comment deleted?
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« Reply #2 on: December 03, 2014, 04:02:24 pm »
I wouldn't trade my Cummins for a pair of big blocks........order a good set of motor mounts and get after it.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
Offline flips87c30
« Reply #4 on: December 10, 2014, 11:35:18 pm »
these are the ones i have. they incorporate the gm "clam shell" motor mount i know its a bad picture. they are simple to make, if needed im sure i could make some and they wont be near $260. but i also have the breadbox adapter so my engine is slightly "clocked"
Offline flips87c30
« Reply #5 on: December 11, 2014, 05:07:06 pm »
Thanks Irish. I will have to take you up on that offer. I wouldn't know how to make my own without having some to look at. which would kind of defeat the purpose  :)
« Reply #6 on: December 11, 2014, 10:52:42 pm »
how soon do you need them?
Offline flips87c30
« Reply #7 on: December 13, 2014, 01:43:44 pm »
Take your time Irish. ive got a lot of work to do still. I would really like to box and reinforce the frame. That is going to take me a while. whenever you get around to it let me know.
« Reply #8 on: December 13, 2014, 02:21:27 pm »
ok i plan on pulling the cummins soon to put in the crew cab. just waiting on the Diesel Alternator Tachometer Interface i ordered for my tcu. just got a alt shop to make my alt give a ground signal for a tach. hopefully ill be close within a couple weeks want to paint my frame while im working on it all also lol
« Reply #9 on: December 15, 2014, 11:11:14 pm »
Just got my alternator from the shop. Cost for the tach part was 25 he also replace the bearings for 30. So now I got to get busy, but you said you could make the motor mount if I drew them up like a blue print you could make it? I think part of is it bent so you might need a brake
Offline flips87c30
« Reply #10 on: December 16, 2014, 04:31:36 pm »
A decent set of plans would probably be all I need. Im pretty good friends with the local welder ;D  Once I get the cummins in the shop and some plans from you I don't see how it could be that hard. The motor mounts may be the easiest thing I have to fabricate for this entire build.
