Diesel Engine Discussion
Cummins Swaps
(Moderator:
bajaburban
Cummins or Duramax or Detroit thoughts
Topic: Cummins or Duramax or Detroit thoughts (Read 32431 times)
Engineer
December 01, 2014, 07:05:47 pm »
Everybody is doing the Cummins swap thing. If I were going to build a rig with a diesel I'd go Duramax. If for no other reason than to be different.
The Cummins will probably be cheaper, but I'm a GM purist and would love a square body with a Duramax to tow with.
The Cummins is an excellent engine, you just don't find them in anything GM.
Anyhow, OP, good luck with your build.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
flips87c30
Re: Cummins or Duramax or Detroit thoughts
December 01, 2014, 08:20:23 pm »
Thanks. I haven't heard great things about the duramax. Plus I wouldn't know where to start. There is a lot of information on the Cummins swap. I do get where your coming from though. Unfortunately I am not the guy for the job. I'm going to have my hands full just swapping in a Cummins
Last Edit: December 01, 2014, 08:30:34 pm by flips87c30
87 v30 duelly dump truck 454, th400, np205, dana 60/14 bolt, warn hubs, gmt800 mirrors and LEDs all around the bed.
LTZ C20
December 01, 2014, 10:10:56 pm »
As engineer said, I would also use a Duramax, I work with them every day and they are very reliable and can also be upgraded alot. Not to mention, the Cummins being so big is a tight squeeze, the Duramax engine itself is about the size of a 454, so there's enough room and probably won't be as hard to squeeze in the engine bay.
LTZ Cheyenne C20
December 01, 2014, 10:25:28 pm »
I think he is pretty committed to the Cummins, moving this off out of his project post if we want to discuss Duramax setups.
Now I too would do one. Here is one in a 4x4:
http://www.lonniesperformance.com/82chevyduramax.htm
2wd:
http://www.dieselpowermag.com/features/chevy/1303dp_1976_chevy_c10_the_ultimate_swap/
Last Edit: December 01, 2014, 10:31:59 pm by Captkaos
pocale
December 02, 2014, 10:50:31 am »
Two characters: V and 8
flips87c30
December 02, 2014, 11:13:06 am »
I think we could go back and forth all day about whether Cummins or dmax is better. There are tons of threads all over the internet doing just that. But I can find a Cummins for a couple thousand bucks around here all day long. No such luck for a duramax. Maybe they are out there though I don't know
zieg85
December 02, 2014, 11:18:47 am »
Someday I hope to talk a childhood friend of 45 years out of his 67 C20 that has a 3-53 Detroit Diesel in it. The truck is rotting where it sits but it sure was a neat yard truck some 30 years ago when I used to run around in it.
OneLowOneTon
December 02, 2014, 02:03:07 pm »
Would love to put a 4-53 Detroit in mine but without a body lift the motor is entirely to big. Love the sound of a good Detroit. Am contemplating the same decision right now as I am debating a diesel swap in my truck.
1HI4x4
V30 Crew now a shortbed.....
December 02, 2014, 02:14:20 pm »
Hard to beat the simplicity and raw torque of a Mechanical Pump Cummins........ I have one in my V30, I have owned several big block square bodies and there is no comparison in the power. 6 in a row is the way to go.........
I understand the purist wanting a Dmax in these trucks, they are a ton more complicated to install and not nearly as easy to upgrade. I can change all 6 injectors in my Cummins before you can pull one in a Dmax.
I would love to have a GM Allison behind my Cummins though.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
OneLowOneTon
December 02, 2014, 03:34:57 pm »
Have considered just putting in a 6.5 turbo. Truck is not used for pulling just for show and driving. How you put the price difference between maintenance and up keep between running a diesel and gas? Or a Cummins and dmax?
roundhouse
December 02, 2014, 05:53:06 pm »
GM purist ?
I thought the duramax was designed and built by Isuzu ?
And the 6.2/6.5 was designed and built by Detroit ?
Last Edit: December 02, 2014, 05:57:08 pm by roundhouse
1HI4x4
December 02, 2014, 05:55:32 pm »
Like.......
December 02, 2014, 08:18:06 pm »
OneLowOneTon, I know a few people personally that daily a lowered 88-99 dually with a 6.5L turbo. As far as maintenance I think it would be a toss up I guess.
The 6.5L will probably yeild more fuel mileage that a gasser in the 1 ton. And it will bolt right in place. I put a 6.2L in mine for the same reason.
Keep in mind that if you use a 88-98 turbo 6.5 you will have to modify the AC ducting.
I like the Duramax due to the outside the norm but they are pricey. I can tell you if a Cummins came up I would be very tempted though as long as it was mechanical.
OneLowOneTon
December 02, 2014, 09:40:12 pm »
Roundhouse the 6.2 and 6.5 are Detroit's and were designed by the GM division Detroit Diesels.
I'm still looking into the 6.5 turbo swap, I will removing my heater and ac box and smoothing the firewall some so I will have the extra space for the turbo and downpipe. But ialso have my eye on a mechanical 5.9 right now. Just curious as to the mod and cost difference to go Cummins
LTZ C20
December 03, 2014, 01:56:30 am »
6.5 all day long, or Duramax. I love Dmax's, great engine. But I also love the clatter and noise from a 6.5 at idle that just screams "I'm A DIESEL!"
LTZ Cheyenne C20
Cummins Swaps
(Moderator:
bajaburban
