Author Topic: Electrical Question  (Read 4961 times)
Offline dvdswan
Electrical Question
« on: December 07, 2014, 10:56:13 pm »
Ok, so I know my wiring has been cut and spliced all over the truck so I'm hoping this is the reason why.  I replaced the taillights on the truck today with ones that are supposed to be there.  PO had installed trailer lights on instead of ones that had reverse lights to save a couple of bucks I'm guessing.
The question is, the brake lights will only come on with the ignition on, I thought you should be able to hit the pedal and the lights would come on with the key out of the ignition.  Which way should it be?
I know turn signals need the ignition on, hazards do not.
Another thought, the side markers on the front will blink with the blinkers but the rear side markers do not.  Is this correct or should they blink as well?  78 K10 Stepside BTW and yes the taillights are working as designed with the truck running.
Re: Electrical Question
« Reply #1 on: December 08, 2014, 12:47:02 am »
Brake lights are powered from fused B+.  The supply is always hot.
The front side markers double as turn indicators, the rear side markers are strictly running lights and do not flash.
Offline roundhouse
« Reply #2 on: December 08, 2014, 06:31:07 am »
The power source Might have been changed From he battery to the ign switch for some unknown reason
If everything works I wouldn't mess with it
Offline dvdswan
« Reply #3 on: December 08, 2014, 07:15:50 pm »
thanks guys.  I thought you should see them with no power.  I'm going to mess with them until I do the restore, then all the wiring will be replaced.
Offline NCali
« Reply #4 on: January 01, 2015, 07:39:35 pm »
And yes you should have brake lights when the ignition is off
 However If your harness was spliced at the brake light switch and the brake lights work the way they are connected I wouldnt mess with the connections unless you are proficient with wiring diagrams .
Black Labs Matter
