Author Topic: 81 k10 longbed stepside brake drum/front end issue  (Read 7521 times)
Offline moneyg77
« on: December 15, 2014, 12:16:28 am »
Hi all, I have an 81 k10 longbed stepside issue/front driveshaft issue
1.) Driveshaft-when I put it in 4x4 it rubs in the front..i just had a used shaft rebuilt and I was wondering if anyone could help me with that.
2.) Brake drum-when I first get on the brakes the rear locks up with light pressure, but after getting on it a couple times before I leave the house it does fine. I'm going to a buddy to get a diagnostic but was wondering if any of you guys knew what it could be so I can fix it. I've never messed with them so this subject is foreign to me.
PLEASE HELP!!!
1981 K-10 longbed stepside 350/465/208/quadrajet. 6"lift, 35" BFG, custom exhaust
1983 K-10 swb 4"lift
1986 lwb fleetside
Offline fitz
Re: 81 k10 longbed stepside brake drum/front end issue
« Reply #1 on: December 15, 2014, 04:13:18 am »
Does your truck have a lift kit?
Where does the front shaft rub?
« Reply #2 on: December 15, 2014, 10:48:21 am »
Are the rear brake cylinders leaking?  Any work been done to them recently?  Have you inspected them.
squarebody.biz
Offline roundhouse
« Reply #3 on: December 15, 2014, 05:11:15 pm »
The rears locking up sounds like a leaky axle seal
If axle oil gets in the drum it will make the brakes lock up easy
Offline moneyg77
« Reply #4 on: December 16, 2014, 08:45:29 pm »
There was leaking inward side of both brake drums and yoke, as well as the front.
I went to have my issues diagnosed and after 5 minutes the mechanic said that there was no need. He said that when I had the front end rebuilt the mechanics didn't know what they were doing. He says the front end is not operating properly because they did it wrong and didn't assemble the hub lockouts in addition to any diff issues already in existence.
Rear end - he said the yoke had way too much play which could mean the rear diff is shot. He recommended I just go out and find new axles. He said mine were too tired would require a full rebuild. He says he's trying to save me monry.
Any opinions??
1986 lwb fleetside
Offline moneyg77
« Reply #5 on: December 16, 2014, 09:03:30 pm »
It has a 6" BDS lift with 35's. I can go more in depth with mods if necessary. Looks like I may need to just find some more axles..if so, I'm gonna go 3/4 ton. Know anyone getting rid of some in the Midwest?
1986 lwb fleetside
Offline roundhouse
« Reply #6 on: December 16, 2014, 09:08:06 pm »
The 3/4 ton front axle is he same as yours
Just with a 8 bolt hub and rotor
Offline moneyg77
« Reply #7 on: December 16, 2014, 10:05:56 pm »
Mine came from an 84 blazer
1986 lwb fleetside
