Author Topic: BACKFIRE  (Read 4238 times)
Offline 1986GMCSierra
BACKFIRE
« on: December 21, 2014, 11:01:37 am »
My stock 1986 GMC 305 has a high idle problem and after she gets warmed up she backfires uncontrollably... i was thinkin the timing might br off a little but that doesnt fix the high idle.. Need help guys. thanks
Offline 78BIG-TEN
Re: BACKFIRE
« Reply #1 on: December 21, 2014, 05:49:58 pm »
Choke being stuck could cause the high idle and also deliver to much fuel and
fouled the plugs causing your backfire
Re: BACKFIRE
« Reply #2 on: December 21, 2014, 06:00:58 pm »
wheres it backfiring out of? but high idle could be a vacuum leak, the vacuum lean would cause a lean condition and the lean condition might lead to higher temps and cause pre detonation? again this is 100% a guess but might be plausible
Re: BACKFIRE
« Reply #3 on: December 23, 2014, 09:57:25 am »
its coming out of my exhaust if thats what you mean?
Offline rich weyand
Re: BACKFIRE
« Reply #4 on: December 23, 2014, 01:39:45 pm »
Check your timing and that the distributor is clamped down tight.  Temperature changes in the winter can loosen a marginally tightened distributor, which will then rotate with the rotor shaft to a more retarded setting.  Retard it enough, and you will get backfires (actually, afterfires, since they are coming out the exhaust, not the carb).
Re: BACKFIRE
« Reply #5 on: December 23, 2014, 03:42:32 pm »
ok i will check my distributor thanks
