73-87 Chevy & GMC Trucks
air distributor box
Topic: air distributor box (Read 3032 times)
jonny
air distributor box
December 25, 2014, 08:08:20 pm »
I've got an 87 scsb, that I was changing heater coil an broke my air box. I looked on line an in , but didn't have any luck. my bone yards around here don't keep anything this old. does anyone have any ideas? thanks
frotosride
Re: air distributor box
December 25, 2014, 08:18:53 pm »
Plastic Weld...its really simple and if you use the correct type plastic and soldiering iron with plastic tip it will last forever and it's something you can use over and over again. I've used Plastic welding for years and have tried several types of epoxies which have never lasted as long.
frotosride
December 25, 2014, 08:20:29 pm »
Just thought of this but when I replaced my heater core I broke the holes that hold the heat/ac flapper and I plastic welded it back together and installed bushings to prevent wear ont the plastic box.
FlatBlack77
Cheap Fast Reliable - Pick 2
December 25, 2014, 08:59:02 pm »
plastic welding works pretty good as mentioned above.
on top of that you could do something like this
https://www.youtube.com/watch?v=-GMl6J7G7R8
without actually buying the kit from eastwood you can do the exact same thing with regular staples and a blow torch/heat gun. hold the staple with plyers, heat it up, and press it into the plastic.
just an idea if its in a weak spot that needs some added strength
air distributor box
