Author Topic: Engine mounts/Position  (Read 14169 times)
Offline Chevy454hp
« on: December 26, 2014, 11:39:22 am »
What mounts and what placement(2.5'' forward/1'' rearward) of the engine did you find that works best? Trying to decide which engine mounts to buy. I have the original "clam shell" mounts now and have looked at mounts from Dirty Dingo, MR, Hooker, Ebay?, and Jegs. I have seen just flat plate adapters, solid mounts and adjustable ones. I'm not concerned about the trans cross member, I have a lot of room to move it or can build a new one.
Truck is a 77 c10 2wd, I also plan on using the factory ls truck oil pan and accessories drive system if possible.
If this is a repeat thread I'm sorry, I searched trough all the ls threads.
Offline FlatBlack77
Re: Engine mounts/Position
« Reply #1 on: December 26, 2014, 01:50:30 pm »
what transmission?
Offline Chevy454hp
« Reply #2 on: December 26, 2014, 03:44:02 pm »
Sorry, 4l80e.
« Reply #3 on: December 27, 2014, 12:57:47 am »
why move the motor?
Offline FlatBlack77
« Reply #4 on: December 27, 2014, 06:17:06 am »
hes not looking to move the motor, he just wants to know how the motor should sit once it is installed.
« Reply #5 on: December 27, 2014, 06:31:48 am »
missed the Ls part
« Reply #6 on: December 27, 2014, 11:47:21 am »
I used the Plates.  The S&P ones put it where the SB used to mount.  You will have to move the trans crossmember due to the 4L80E.  See my whole built thread on my truck for info.
Offline LSXCHEVY
« Reply #7 on: December 27, 2014, 06:55:12 pm »
IMO the dirty dingo sliders will put everything where you will need it, I just swapped in lq4 with 700r4...i was actually able to mount to clam shells and slide motor back into trans dowels....plenty of room to tighten up everything...
Offline Chevy454hp
« Reply #8 on: December 29, 2014, 09:35:57 am »
How do you think the sliders will hold up to horsepower? Truck is going to be somewhere near 600.
Offline LSXCHEVY
« Reply #9 on: January 06, 2015, 10:44:26 am »
not sure on the HP tolerance for these... I plan on only an approx. 420hp
« Reply #10 on: January 10, 2015, 01:08:14 pm »
you should be fine on power.
