Author Topic: AFTERMARKET TACH  (Read 29885 times)
Offline LTZ C20
Re: AFTERMARKET TACH
« Reply #15 on: December 28, 2014, 10:20:23 am »
Hey FlatBlack,  I mounted mine on the column. Mine is small tho, about the size of the quarter gauges, I mounted it so that in park, it's down on the left side by the headlight switch, when you pull the shifter down into gear, the tach rotates over to just under the left blinker where it can be seen but not obtrusive.
LTZ Cheyenne C20
Offline 1986GMCSierra
« Reply #16 on: December 28, 2014, 11:25:32 am »
i was goin to get this tach but i wsnt sure where to put it
its a glowshift Black 7 Color 2" Tachometer Gauge but i wasnt sure where to mount it
Offline LTZ C20
« Reply #17 on: December 28, 2014, 11:29:27 pm »
Mount it on the column like I did in the pic I sent you. You can see its mounted on the part of the column that rotates with the shifter. Only held on by the bracket is came with and some black zip ties.  Been there for about 11/2 - 2 years or so.
That's a nice tach by the way.
LTZ Cheyenne C20
« Reply #18 on: December 29, 2014, 10:45:45 am »
i will probably mount it like you had it and thanks their pretty cheap too
Offline LTZ C20
« Reply #19 on: December 29, 2014, 12:35:13 pm »
Cool post a pic when you get it done. Good to know, your welcome.
LTZ Cheyenne C20
« Reply #20 on: December 29, 2014, 03:51:15 pm »
i will but it might be awhile i just bought a gun so i will wait a while to buy it
Offline LTZ C20
« Reply #21 on: December 29, 2014, 06:56:51 pm »
Haha nice. I did too bout a month ago.
LTZ Cheyenne C20
« Reply #22 on: December 29, 2014, 09:28:45 pm »
cool what did u get if u dont mind me asking
Offline LTZ C20
« Reply #23 on: December 29, 2014, 10:13:32 pm »
I don't. S&W M&P Shield 40. What did you get?
LTZ Cheyenne C20
« Reply #24 on: December 30, 2014, 12:01:18 am »
Winchester sxp black shadow 12 ga.  What strap did you use to mount the tach to your column?
Offline LTZ C20
« Reply #25 on: December 30, 2014, 01:00:14 am »
Nice! I used some black zip ties. But you could also use those stainless steel "zip ties" that are for exhuast wrap, find a way to bolt or screw it on, or go around a few laps with electrical tape lol. All depends on what you want. For me, zip ties were the easiest, plus I smack it with my knee when I get out sometimes so I can also move it back if a bump it too far.
LTZ Cheyenne C20
« Reply #26 on: December 30, 2014, 09:48:53 am »
ok cool i will try zipties
Offline LTZ C20
« Reply #27 on: December 30, 2014, 09:51:20 am »
Pictures when done.
LTZ Cheyenne C20
Offline lastwords1978
« Reply #28 on: December 30, 2014, 10:23:08 am »
I mounted a small tack in the pocket above the heat controls.
« Reply #29 on: December 30, 2014, 12:34:59 pm »
can you show a picture.. and what did u use to mount it?
