Author Topic: AFTERMARKET TACH  (Read 29884 times)
Offline lastwords1978
Re: AFTERMARKET TACH
« Reply #30 on: December 30, 2014, 12:45:06 pm »
I used the cup bracket that came with the tack mounted to the side of the pocket.  Drilled a hole in the back for the wires.  I get a picture next time I'm out at the farm it's stored at.
Offline LTZ C20
« Reply #31 on: December 30, 2014, 02:18:59 pm »
That would work on trucks without a/c. If you have a/c, there is a vent in place of the pocket.
LTZ Cheyenne C20
Offline 1986GMCSierra
« Reply #32 on: December 30, 2014, 05:24:51 pm »
i have a/c so it probably wont work
Offline LTZ C20
« Reply #33 on: December 30, 2014, 05:34:12 pm »
Nope. So do I. The only other thing I can think of is, based on your needing a tach, you don't have one. So your dash should consist of a large speedo and fuel gauge and 3 small oil pressure, water temp and alt gauges. The forth small spot is either empty with a filler design, should be black plastic with a white circle or a clock in that position. Is this correct?
Some people have removed the empty spot or clock and cut out the plastic to fit various aftermarket gauges such as tach or trans temp etc.
You could do that also.
LTZ Cheyenne C20
« Reply #34 on: December 30, 2014, 06:06:50 pm »
yes thats correct there is nothing there in that fourth spot.... i thought about putting it there but i dont want to have to look down to see my rpm.. i am guessing thats why you mounted yours on the column
Offline LTZ C20
« Reply #35 on: December 30, 2014, 07:49:18 pm »
That's correct.
LTZ Cheyenne C20
Offline rich weyand
« Reply #36 on: December 31, 2014, 01:10:42 pm »
I got the gm sports salvage combination tach and fuel gauge to replace the big fuel gauge.
http://www.gmsports.com/content/new-tachometer-1973-1986-chevy-and-gmc-trucks
Installation was simple, and it looks and works great.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=28547.0;nowap
« Reply #37 on: December 31, 2014, 01:40:11 pm »
thats a lot of money just for a tach but the outcome of puting it in is awesome... your set up looks really clean and well done... but for the money i will probably stick to the column mounted one. thanks for the suggestion though
Offline ackland3
  • Shade Tree Certified Mechanic
« Reply #38 on: January 19, 2015, 09:54:32 pm »
I like the gauges above the ac controls how exactly did you do that?
1985 K10
305
« Reply #39 on: January 20, 2015, 09:21:29 am »
i am not the one who did that but if u have ac it wont work because that is where one of your ac vents are
