Author Topic: 305 FAST IDLE  (Read 5804 times)
Offline 1986GMCSierra
305 FAST IDLE
« on: December 28, 2014, 10:58:22 am »
i have a 1986 stock 305 and 700r4 tranny.. what carburetor  would be best to stop a high idle and get a little more power out of the motor?
Re: 305 FAST IDLE
« Reply #1 on: December 28, 2014, 12:17:15 pm »
High idle is a sign of a vacuum leak
Re: 305 FAST IDLE
« Reply #2 on: December 28, 2014, 01:23:22 pm »
i guess it could be coming from my intake manifold both where it mounts to block and where carb mounts to it..
Re: 305 FAST IDLE
« Reply #3 on: December 28, 2014, 01:24:29 pm »
what is the easiest way to check for a leak?
Re: 305 FAST IDLE
« Reply #4 on: December 28, 2014, 01:33:37 pm »
No easy way. Could be a vacuum hose leak, could be the carb or carb or intake gasket. Try and listen for a sucking sound. If you have some sort of starting fluid you can spray that around the carb and intake or something flammable like a propane torch not lit but turned on a engine vacuum leak could suck it up and will raise the idle
« Last Edit: December 28, 2014, 01:38:36 pm by Irish_Alley »
