Body, Glass & Paint
Heater box seal
Topic: Heater box seal (Read 9300 times)
Ds2014
Heater box seal
December 28, 2014, 11:42:07 am »
I have an 81 step side short wheelbase under restoration,what do I use to seal the heater box back to the firewall?
Thanks Don
Blazin
Blazin new trails!
Re: Heater box seal
December 28, 2014, 08:13:54 pm »
I have used butyl tape like what they used to use to install windshields. I have also used the two sided urethane foam tape that is used for metal roofing. You lay it on top of the rib that is to be overlapped by the next sheet / panel of metal.
ehjorten
Re: Heater box seal
January 05, 2015, 08:57:46 am »
I got a roll of 3/8" round butyl rubber and used that.
-Erik-
Ds2014
Re: Heater box seal
January 05, 2015, 10:31:52 am »
Where did you get it?
ehjorten
Re: Heater box seal
January 05, 2015, 11:34:59 am »
I got it from a local windshield repair supply house. They actually just gave me the roll!
-Erik-
ehjorten
Re: Heater box seal
January 05, 2015, 11:43:05 am »
Looks like RV Wholesalers has some rolls. Doesn't really matter if it is round or flat. The 3/8" round that I had was a little thick. I needed to squish it down a lot. A flat strip of 3/16" x 3/4" or 1" would probably work well.
-Erik-
Ds2014
Re: Heater box seal
January 05, 2015, 05:45:30 pm »
Cool thanks
Blazin
Blazin new trails!
Re: Heater box seal
January 06, 2015, 09:31:10 am »
Your local lumber yard has the urethane roofing tape.
Body, Glass & Paint
Heater box seal
