Author Topic: Going nuts over here  (Read 15694 times)
Offline jay6776
    • Cars I Have Done
« on: December 28, 2014, 05:59:41 pm »
I want to replace the wheels on my 85 need new tires. So might as well up date the wheels to. Looking to get Corvette rallies. But not sure on what back spacing I need. Right now I have 15 x 8 on the front and 15 x 10 on the back . Tire sizes are 225/70/15 and on the back its 275/60 /15.  I don't know the back spacing of the rim.
I have 2 inch drop spindles on the front and i think 3 inch drop shackles on the rear. The Rear was going to go with 10 inch wheel with 5 inch back space. The front is were the prob comes in. Right now can not balance the wheel cuz it will knock the weights off.( sticky weights or out side ones) So not really sure what back spacing I should use on the front. Would a 8 inch wide with 4 inch back spacing work?
the photo is how it sits now
And Than on the tires to me the 275 /60/15 on the back is to small for a 10 inch wheel. the tire i have on there is bowing in the middle
Would like the back to be the same wide but like 1 inch taller
and would like the front little taller to
« Last Edit: December 28, 2014, 06:01:51 pm by jay6776 »
Re: Going nuts over here
« Reply #1 on: December 29, 2014, 01:16:49 am »
In order to balance a wheel you have to remove all weights anyway
Offline roundhouse
« Reply #2 on: December 29, 2014, 11:16:00 am »
Those wheels look great !
Slightly taller tires would be perfect
Offline roundhouse
« Reply #3 on: December 29, 2014, 11:19:23 am »
You can also use airsoft pellets inside the tire to balance it and some company makes stainless pellets small enough to install thru the valve stem
I know guys that use airsoft pellets or stainless ball bearings inside their large off road tires to balance them
« Reply #4 on: December 29, 2014, 12:09:38 pm »
factory 15x8" wheels had 4" backspacing, so...
Do they have the stick on weight and the control arm is knocking them off?
Offline 78BIG-TEN
« Reply #5 on: December 29, 2014, 04:28:00 pm »
My 78 kept knocking them ,had to trim the lower control arms to get clearance for weights
Offline DuckAholic1
« Reply #6 on: December 29, 2014, 05:06:57 pm »
Never heard of this before! Question.. How would little balls rolling around inside the tire balance it??? Forgive me if that's a dumb question!! A little sleep deprived right now!! :o
Offline jay6776
    • Cars I Have Done
« Reply #7 on: December 29, 2014, 05:17:00 pm »
Well if I use the stick weights the caliber knocks them off. And If I use the weight on the outer lip the tie rod end knocks it off. But went out there last night and I think them front wheels have 4.5 back spacing. So I might just get a  1/2 spacer that would give me the clearance I need.
Offline roundhouse
« Reply #8 on: December 30, 2014, 08:46:10 am »
Here's a demo of the ceramic beads that are small enough to fit thru the valve stem
Keep In mind that the quality of tires is not as good as it used to be and quite a few come from the factory egg shaped or with a small section of the sidewall weaker than  the rest so with weight on it it bounces
The only way to find those are with "road force balancing"
A machine that actually puts weight on the tire as it spins on the machine to simulate being on a vehicle
http://www.youtube.com/watch?v=eq263AYgyYg&feature=youtube_gdata_player
Offline roundhouse
Offline roundhouse
« Reply #10 on: December 30, 2014, 03:05:51 pm »
The tire should be at least two inches wider in the sidewall than the rim
Offline jay6776
    • Cars I Have Done
« Reply #11 on: December 30, 2014, 09:36:12 pm »
That is pretty neat. When you first posted that i thought you were joking around. Did you do this with your tires? How did it work?
Offline roundhouse
« Reply #12 on: December 31, 2014, 07:51:28 am »
Used it in the tires on my 18 wheelers
I've got a tire on my bronco that can't be balanced
Gonna try some in it
Offline Stewart G Griffin
« Reply #13 on: January 04, 2015, 11:12:02 am »
i actually use these:
http://www.counteractbalancing.com/
But i can't comment how well they work because all my tires are out of round because today's tires just aren't very good as you pointed out.  (Hankook i'm afraid to say.....)
i don't put them in thru the valve stem though----i just open the bag dump them in the tire.  You have to be careful when doing that so as not to get any of the product in the bead area of the tire which would cause a leak.    Counteract prefers you put the whole bag in the tire, but what i've found is that the bag didn't disintegrate like it was supposed to and let the product roam freely in the tire.  Maybe i just didn't put that many miles on it before i had to dismount the tire? (due to tire needing to be replaced)
Offline LTZ C20
« Reply #14 on: January 04, 2015, 11:55:43 am »
I took a few minutes to explore your provided link Stewart, very interesting read. Thanks.
LTZ Cheyenne C20
