Author Topic: Upper control arm clearance.  (Read 6575 times)
Offline rockbottomc10
« on: January 05, 2015, 02:43:54 pm »
Hey everyone. I'm in the process of bagging the front of my 78'. Going with a 1.5" channeled oem crossmember. So in the future I'll be trying to deal with steering shaft clearance issues. Has anyone modified the oem upper control arm on drivers side with a notch to clear the stock steering shaft while aired out? I'm thinking something alone the lines of the Michigan metalworks dodger arms.
ROCKBOTTOMC10👎
ROCKBOTTOMC10👎
Re: Upper control arm clearance.
« Reply #1 on: January 05, 2015, 09:13:49 pm »
I recommend using borgeson joints and routing it around everything.
« Reply #2 on: January 05, 2015, 09:52:31 pm »
Oh nice. Thanks for the info. Is this what you have done in the past with your channeled x member? Ps I am following your link to do mine. Good site nice to have a guy like you in our back pocket!
ROCKBOTTOMC10👎
ROCKBOTTOMC10👎
« Reply #3 on: January 05, 2015, 10:31:41 pm »
Yes.  I can also show you a must faster way to mark them for cutting.
squarebody.biz
« Reply #4 on: January 06, 2015, 01:24:36 am »
Ya for sure dude - let me know!
ROCKBOTTOMC10👎
ROCKBOTTOMC10👎
« Reply #5 on: January 10, 2015, 01:41:05 pm »
I am going to try and explain it in test to go with the pics..
What you are trying to do on the front is make 3 tape sections with 1.5" tape.  2 and the upper section and 1 at the lower.
Make 6 vertical lines front. 1 at the edge where the upper control upright is, another at the "end" of the that straight section one at the bottom 45 degrees off the top and another at the "end" of that piece and then another 45 degrees up to the next section and the lat one at the edge of the opposite upper control arm upright.
Then with 2 the 45 degree angles from the bottom one up to the top 2 use 2" tape and set it up to hit the vertical lines.
On the back you will have to use the same principle, but it isn't easy to use 45 degrees, you can use 60 degrees but the tape has to be close to 1.3"wide ran at that angle.
The ones below are at 45 degrees using 1.5" and 2" wide tape, and we scribed the bottom with a 1.5" wide curve to allow it to sit down flush
If you do it this way it sits right down with no gaps.  ( I always kept the "humps" in mine)
« Last Edit: January 10, 2015, 02:04:28 pm by Captkaos »
« Reply #6 on: January 18, 2015, 12:00:37 pm »
Nice work. So I'm assuming the two outside tape lines are  basically for the outside frame rail vertical drops. Correct?  Also after reinstallation do you build brackets on top of the frame to back the top of the vertical brackets? That's k a lot this is very helpful.
ROCKBOTTOMC10👎
ROCKBOTTOMC10👎
« Reply #7 on: January 19, 2015, 10:36:03 am »
The ones that wrap over the top?  It is for the edge cut for the frame to sit.  It has to be cut behind the cut line.
Reinstalling you just bolt it back in and redrill the holes from the upper bracket that can be drilled.
« Reply #8 on: January 23, 2015, 01:41:20 pm »
Nice thanks a lot capt kaos!
ROCKBOTTOMC10👎
ROCKBOTTOMC10👎
