Author Topic: Why two oil sensors?  (Read 3377 times)
Offline Stewart G Griffin
« on: January 05, 2015, 10:33:40 pm »
This has probably been discussed before, but why are there two oil senders on my 305?   One is near the distributor which is one prong and another near the oil filter which is two pronged?
Offline enaberif
Re: Why two oil sensors?
« Reply #1 on: January 05, 2015, 10:35:54 pm »
Oil Pressure & Oil Light most likely.
Offline jaredts
« Reply #2 on: January 06, 2015, 12:02:27 am »
One is for the gage or idiot light, and one is a pressure switch for the electric choke.
« Reply #3 on: January 06, 2015, 09:01:02 am »
What year?  There might be two just like there's two coolant sensors. One for the ecm the other for the gauge/light. Don't think I ever seen a truck with a idiot light and gauge. Most time if you have gauges you will have a check engine light go on if something is reading high. Like before you start the truck you have a cel light.
But if memory is right the one up on the distributor is for the gauge the one by the filter is ecm. Think we talked on here about the difference in a sensor and switch. Most time there's too much confusion and they are called the same thing.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=28815.msg240707#msg240707
« Reply #4 on: January 06, 2015, 09:32:51 am »
One is for the choke, the other for the gauge, or light which ever you have.
