Author Topic: 1 ton or 3/4  (Read 12045 times)
Offline srozell
    • My 1980 Chevy
1 ton or 3/4
« on: January 06, 2015, 02:54:45 pm »
Okay, so the tires I've got on my truck were the same tires that were put on the truck in 1987. I didn't have enough traction to move forward on pavement  in 4WD in 1" of snow.
I looked online, and according to any specs I found, my truck should have the 6 studs at 5.5, but it actually has 8 studs at 6.5.
Aren't these 1 ton axles?
Was this specific to the "Camper Special" or has someone swapped the axles out on this truck?
Can anyone help me make sense of what I have here?
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
Offline timthescarrd
Re: 1 ton or 3/4
« Reply #1 on: January 06, 2015, 03:14:31 pm »
All the 73-87(91) 3/4ton and 1ton came with 8 lug wheels, there were a variety of axles used.  1/2ton (K10 K1500) trucks came with 6 lug. What is your truck? Year, model?
Offline ehjorten
Re: 1 ton or 3/4
« Reply #2 on: January 06, 2015, 03:56:38 pm »
My '77 K20 has 8 lug
-Erik-
Re: 1 ton or 3/4
« Reply #3 on: January 06, 2015, 03:56:54 pm »
the 20 behind your door ¾ ton, 30  means 1 ton. (but this doesnt mean someone didnt swap axles)
½ use 15" rims with 5 lugs for 4x2 or 6 lugs for 4x4.
while ¾ & 1 ton use 16" rims with 8 lugs for both 4x2 and 4x4. now you can use 15" rims instead of the 16 but they wont fit without grinding down the caliper
Offline srozell
    • My 1980 Chevy
Re: 1 ton or 3/4
« Reply #4 on: January 06, 2015, 04:18:29 pm »
Thank you.
The truck came with 16.5 rims so I'm swapping them out for 17's, and I'm putting winters on for now that will transfer over to my FJ Cruiser after I lift and put 35's on this.
I'm kinda sad that the rims won't swap over, as they would have if it was a 6 bolt, but I'm happier for the heavier axles.
1969 K20 Step Side
Re: 1 ton or 3/4
« Reply #5 on: January 06, 2015, 05:17:03 pm »
That's a full-float axle, being a single-rear-wheel, it should be a GM Corporate 14-bolt, they were put on a few 3/4tons but mostly used for 1ton. (there are other differences including springs and frame)  10.5" ring gear, very strong axles
Re: 1 ton or 3/4
« Reply #6 on: January 06, 2015, 07:05:17 pm »
Your online search was probably a K series 3/4T.  If you look under V20 you'll find the correct info
Offline srozell
    • My 1980 Chevy
Re: 1 ton or 3/4
« Reply #7 on: January 06, 2015, 10:53:20 pm »
Thanks for the additional info.
1969 K20 Step Side
Offline roundhouse
Re: 1 ton or 3/4
« Reply #8 on: January 07, 2015, 06:45:58 am »
The 3/4 ton front axles were the same as 1/2 ton
Just used 8 lugs instead of 6 ?
Re: 1 ton or 3/4
« Reply #9 on: January 07, 2015, 08:14:05 am »
pretty much
