Author Topic: door hinge  (Read 5116 times)
Offline 79mc
door hinge
« on: March 27, 2002, 05:38:00 am »
What is the easiest way to remove the bolt that points out on the upper hinge? 87 PU.
Thanks
DougV>
Offline 73K20
Re: door hinge
« Reply #1 on: March 27, 2002, 08:42:00 am »
There is no easy way that i know of.  Take the dash pad off and start disassembling from there.  The drivers side take out the gauge panel and on the passenger side pull the glovebox out.  The bolt head is probably behind a rubber gromet that runs the hot wire for the interior lights down to the door switch.  Also a universal joint comes in really handy.
Offline 79mc
Re: door hinge
« Reply #2 on: March 27, 2002, 04:37:00 pm »
Thanks alot.I was afraid that might be the case. I wonder why they didn't make it point the same direction as the other two.
Thanks again
DougV>
Re: door hinge
« Reply #3 on: March 29, 2002, 08:44:00 pm »
One of fords better ideas, they didn't use it. That bolt pionting outwards is a real pain. I have never needed to take the top hinge off except when striping a truck.
Offline 79mc
Re: door hinge
« Reply #4 on: March 30, 2002, 07:42:00 pm »
I had to adjust both top hinges to get my "new" used doors to line up properly.
DougV>
Offline wolfie
Re: door hinge
« Reply #5 on: July 13, 2010, 05:55:22 pm »
I have the same issue with my 77.  I got a new used door and need to adjust it forward to get a little room in the upper rear corner where it is currently rubbing against the cab.  If I loosen the top hinge (including the one pointing outward) will I get the forward adjustment I need?
Wolfie
1977 GMC K15 4x4
400
