Author Topic: Re-installing AC  (Read 47813 times)
Offline CA Big Red
    • Big Red Squarebody
Re: Re-installing AC
« Reply #15 on: February 07, 2016, 10:54:30 am »
I could not get the seatbelt bolts out
"You don't know what you don't know."
1978 Scottsdale Stepside
383 w/ 4" lift & 35" BFG
Offline roundhouse
Re-installing AC
« Reply #16 on: February 07, 2016, 11:01:35 am »
theyre glued in
Gotta use a impact gun usually
Sometimes you gotta use a ratchet with a cheater pipe on it to break em loose
Offline CA Big Red
« Reply #17 on: February 07, 2016, 11:03:34 am »
What do you do when you strip out the star bolt
Offline CA Big Red
« Reply #18 on: February 07, 2016, 11:11:22 am »
I did the cheater pipe, broke the driver side loose...stripped it out...  Can't get passenger side to budge.
Offline roundhouse
« Reply #19 on: February 13, 2016, 06:50:53 pm »
Can you get a pipe wrench on it?
Offline CA Big Red
« Reply #20 on: March 29, 2016, 10:01:03 pm »
Good news: Vice grips for the driver side did the trick. Bad news: Stripped out passenger and can't get the vice grips to work. Can't get pipe wrench on this either.
Offline CA Big Red
« Reply #21 on: March 29, 2016, 10:19:30 pm »
I did replace the door panels.
Offline CA Big Red
« Reply #22 on: March 29, 2016, 10:21:08 pm »
Replaced the seat cover with the upholstery kit
Offline CA Big Red
« Reply #23 on: March 29, 2016, 10:21:54 pm »
Finished in the truck. I wish I would have done this sooner.
Offline CA Big Red
« Reply #24 on: March 29, 2016, 10:22:46 pm »
Now I'm putting a new floor mat down on Sunday.
Offline CA Big Red
« Reply #25 on: March 29, 2016, 10:23:20 pm »
This all started with an AC replacement project.
« Reply #26 on: March 30, 2016, 02:04:40 pm »
You weld a nut to the bolt and remove it while it's hot
Offline CA Big Red
« Reply #27 on: March 30, 2016, 02:12:11 pm »
Thanks Vile. I'll have to get help on that.
Offline hatzie
« Reply #28 on: March 30, 2016, 05:06:32 pm »
So, I bit the bullet. Purchased a VintageAir system. This after I collected everything I needed for the stock system install.  I decided to go Vintage for the guarantee, the technology and a buddy of mine who just put one in and swore by it.
So, I hate to disappoint, but I am going the other direction and will post pics along the way a, but will start a new thread for that.
The project summits underway, but I've been waylaid by the amount of rust I found in the floors.
No disappointment.  That system will get rid of the big ugly lump on the firewall and is engineered from the ground up for R134a right from the get go.  No headaches.  If you can afford it it's the way to go.
BTW the interior looks real clean.  Nice work.
« Reply #29 on: March 30, 2016, 06:21:12 pm »
They really should have designed V-A to work with the factory controls though.
