Author Topic: Thinking of Mickey Thopson Sportman S/R ties  (Read 6528 times)
Offline Wayner
« on: January 12, 2015, 07:53:40 pm »
Any opinions on running 28x12.0-18 on the rear and 28x10-18 on the front. My '76 is lowered on Ridetech airbag system. I'm open on wheels as yet.
Offline Wayner
Re: Thinking of Mickey Thopson Sportman S/R ties
« Reply #1 on: January 13, 2015, 06:46:32 pm »
OK, no takers. What if I said 285/45-18 rear and 265/50-18 front? These are close in metric
Offline Wayner
« Reply #2 on: January 13, 2015, 07:25:29 pm »
This seems to answer the question, not the same numbers but overall size is the same for the front.
This is live85's truck with about a 4/6 drop and my 20's on them with 275/40/20's for the Boss 335 15x8.5 wheels with 5.670" backspacing for those wanting info on a lower setup..
http://forum.73-87chevytrucks.com/smforum/index.php?topic=27604.0
« Reply #3 on: January 13, 2015, 09:25:11 pm »
The front at 10" wide will probably hit. the inner fender depending on how low it is.
Offline Wayner
« Reply #4 on: January 14, 2015, 06:45:19 pm »
Not going to run factory inner fenders, just some steel trailer fenders. What do you think?   :-\
« Reply #5 on: January 15, 2015, 10:13:01 pm »
It should be ok if you mount them high.  Just verify your backspacing and clearance to the fender lip.
Offline Wayner
« Reply #6 on: January 17, 2015, 12:22:58 pm »
Thanks Cap.  8)
Can I assume the backspacing on the white truck (5.670") is good for the 18x8.5 front wheels, Same for the 18x10s in the rear or a little less say 5". It's a Stepside.
« Last Edit: January 17, 2015, 12:37:06 pm by Wayner »
« Reply #7 on: January 19, 2015, 10:45:13 am »
you should be ok.  I would still measure though and keep in mind the tire height.  Those are about 28.5" tall.
